No boost ?
Old Dec 18, 2013 | 07:55 AM
Freddy_Lasers57's Avatar
No boost ?
So i have been having a problem with vibration. Thought it waz the front mount, but not so sure now. Cruizing down the highway I am pulling less vacuum. And when put under load only show 5# on gauge but sounds likeits boosting 20#. Working with an LSJ here. I am wondering if the converter is backed up. Factory Exhaust.
Old Dec 18, 2013 | 08:07 AM
Other way around, plugged cat will cause higher boost levels. You most likely have a huge vacuum/boost leak, check all your vacuum lines and bypass valve
Old Dec 18, 2013 | 05:31 PM
Ok so looking at the bypass from front of car there are 2ports on front and one on back 1 lower front port has no hose. I cannot remember is something missing.
Old Dec 18, 2013 | 09:18 PM
Here is what im talking about
Can anyone send me a pic of what its supposed to look like.
Old Dec 18, 2013 | 09:41 PM
come on guys no help out there
Old Dec 18, 2013 | 10:51 PM
Looks like all lines are here.
its not the valve, it will hold a vacuum. I need to replace vacuum lines, but that's not it. the solenoid well not sure how to check it. I do however hold a vacuum on it from the short upper hose on the valve. I don't get full boost until Im at redline. What effects could the vibration have on this.
Could this be caused by a bad crank balancer, (harmonic balancer) causing vibration and the knock sensor pick them up retarding the timing etc.
I just had my fuel pump replaced due to recall. If it was a fuel related causing low boost, wouldn't I get a code of some sort.
If it was a timing related issue, I would think I would get a code also.
Last edited by Freddy_Lasers57; Dec 18, 2013 at 10:53 PM. Reason: forgot information
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
