Noise when turning sharply at slow speeds
Old Aug 16, 2010 | 01:06 AM
kyledr's Avatar
I started parking in a ramp, and if I drive with the window open, I hear a noise when I'm turning sharply at slow speed. It's not much of a squeek like brake noise, though I can't rule that out, it's just a sharp noise that lasts for about a second out of the turn. One spot it happens almost always is when I'm going down the circular corkscrew exit thing, at the bottom where it straightens out and the incline becomes flat, it'll make a noise there. Any clues?
Old Aug 16, 2010 | 01:14 AM
Phyrric's Avatar
Curb any of your rims badly recently?
Old Aug 16, 2010 | 10:26 AM
Chevrolet Cust Svc's Avatar
kyledr,
I would recommend taking the vehicle into your local dealership to be diagnosed. They should be able to assist you further and have a plan for addressing the issue. If you have further questions, feel free to contact me by email. Thank you.
Tricia, Chevrolet Customer Service.
Old Aug 16, 2010 | 10:46 AM
CudaJoe's Avatar
its your steering motor. Do you slam the wheel all the way to the left or right when turning and hit the bump stop?
Old Aug 16, 2010 | 11:51 PM
kyledr's Avatar
CudaJoe, when this turning is happening at slow speeds, yes, the wheel is fully left or right. I don't know how to tell if it hits the bump stop.
Phyrric, I haven't rimmed the car badly that I know of. How could I check for this?
Do you think maybe the steering motor is the cause and the reason it's bad is the recall?
Old Aug 19, 2010 | 08:46 PM
kyledr's Avatar
OK, now I listened more and I've determined, it'll make this noise in the ramp even when I'm not turning the wheel all the way to the left, in fact I would say it usually isn't turned all the way left or right. About after halfway through my turn it might make a screach noise. That's what I decided it most sounds like. Do you think it's related to the Cobalt recall?
Old Aug 21, 2010 | 06:43 PM
riko540's Avatar
Mine does the same thing. The wheel doesn't have to be turned all the way and mine only seems to do it when I turn right. I thought it may be the tire pressure but I checked it and its fine. My car is going to the dealer to be looked at soon for the CEL that comes and goes randomly so I'll have them check this out as well.
Old Aug 21, 2010 | 06:47 PM
exiged's Avatar
is it like a clicking almost? Maybe the springs aren't seated correctly and are moving when turning at slow speeds causing this sound. . .
Old Aug 22, 2010 | 02:21 PM
riko540's Avatar
Its not a clicking sound. More like a squeal from the tire rubbing on something but I haven't been able to find what exactly it is as there are no wear marks that I could see.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
