non stop problems
Old Feb 16, 2012 | 12:19 PM
dktgarlick's Avatar
non stop problems
I have an 07 ss sc and i replaced my timing chain tensioner last weekend and now i have problems. the car ticks when its cold and also i cant accelerate past 3k rpm. the car bogs down and starts to smoke pretty bad. also i have to keep adding coolant to the intercooler. any ideas??
Old Feb 16, 2012 | 01:26 PM
bluebalt07's Avatar
Pull your SC. I bet you'll find a puddle in your intake mani. I had the same problem with stuttering but its nothing to do with the timing chain tensioner. Mine was my endplate which somehow developed a hole where the cores fit into it. It let coolant get out of the cores and into the intake mani and when I revved past 2.5k it started stuttering really bad and was blowing out clouds of white smoke
Old Feb 16, 2012 | 02:57 PM
Chevrolet Cust Svc's Avatar
It looks like bluebalt07 is giving you some solid advice already, and I don't want to interfere in your plan of action in addressing this issue. However, if you were to decide to work with a dealership on getting this diagnosed (which I understand isn't always the preferred option), please do let me know! I would like to be available to assist as needed.
Sarah
GM Customer Service
Old Feb 16, 2012 | 06:45 PM
dktgarlick's Avatar
How hard was that to fix?
Old Feb 16, 2012 | 10:38 PM
bluebalt07's Avatar
I had to get a new endplate so I had to pull the intake mani off also but not hard. Just take those off, put the new endplate on and then put it all back on the car and connect everything back up
Old Feb 17, 2012 | 01:22 AM
minizr1's Avatar
The Intake mani is really deep. So make sure you get all of
The coolant out I used an old t-shirt and a flat head screw driver
To get deep donne into the intake manifold.
Old Feb 17, 2012 | 01:57 AM
insylem's Avatar
A Few months ago I did the Dual Pass Upgrade,
I might still have my stock endplate arround somewhere pm me if you need it. Its got a peice of hose still glued to it that I couldn't get off. Im sure it could be easily cut off now though.
Old Feb 17, 2012 | 08:28 AM
dktgarlick's Avatar
ok sweet thanks everybody.
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
Dirtybutwhole
Sep 26, 2015 06:53 PM
