odd OBD2 code
Old Jun 22, 2012 | 08:23 AM
TommyTwinCams's Avatar
odd OBD2 code
2004 Saturn Ion 2 Quad Coupe
My parking brake light is constantly on, so I hooked up my laptop hoping I could find a code. I did, but can't find info on it anywhere. The most I was able to find is that it's a GM-specific code.
Code: B2AAA
Anyone have any clue what this code means? I can't find info on it anywhere.
Screencap:
Old Jun 22, 2012 | 09:01 AM
Gelladuga69's Avatar
What scan gauage are you using?
I came across this:
"A module in your vehicle is reporting a code that doesn't make any sense (B2AAA) because it is overwriting the true code and that B2AAA codes is the first code the SG2 is picking up. You can send a command to the ScanGaugeII in order to read the raw data. To do this:
From the home screen select MORE> MORE> CMNDS > choose a memory slot> EDIT> enter the numbers 03> SEND.
Old Jun 22, 2012 | 09:05 AM
I came across this:
It's a ProScan kit for my laptop.
OBD-II (OBD2) Scan Tool Software and Hardware - ProScan
The brake light has been on since I had my transmission and clutch replaced so I'm assuming it's a random disconnected brake sensor.
Old Jun 22, 2012 | 04:02 PM
Nevacme's Avatar
Might be low brake fluid
Old Jun 22, 2012 | 06:52 PM
NO Because I recently had to bleed the brakes when I installed my coilovers. Fluid's fine and plenty of it. Besides, If I was low on brake fluid, I'd probably also have an issue with the clutch.
Old Jun 22, 2012 | 08:18 PM
LS6Rally's Avatar
^ th efluid might not be low, but the sensor might be junk.
do the Saturns not have a DIC???
Old Jun 23, 2012 | 11:59 AM
All I have is a little digital display that tells me mileage, trip, and displays the word "OIL LIFE" when I try to cycle through it without giving me any info.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
