Oil Filter ? while i have a little oil leak...
Old 08-24-2006, 06:49 AM
johnkb8's Avatar
Does this filter come with a gasket or something i just took out the old cartridge style filter and put in the new and tighening it up pretty good (this is like my 5th oil change i did), and now i see oil around the cap and leaked down alot of oil so far, unless something else is wrong, did i do something wrong here, dont know where this oil is coming from and why cause i didnt not spill any oil...
Old 08-24-2006, 02:13 PM
johnkb8's Avatar
come on bump
Old 08-24-2006, 02:34 PM
pierre's Avatar
You probably cross threaded the plastic cap, cracked it or the "O" ring that seals the cap is not in place. I understand you get a new cap with the filter at a GM dealer. I'd start over with a new cap.
Pierre
D4u2s0t's Avatar
are you sure it didn't drip off of the old filter or leak while you had the cap off??
Old 08-24-2006, 04:02 PM
johnkb8's Avatar
did not drip off, cause this is kinda of a lot of oil, and my oil level is still full, but i am pretty sure i didnt cross thread the cap, but maybe i will try and get new cap, anybody got a part number for oil filter cap!!! pleasee say yes
Old 08-24-2006, 04:18 PM
pierre's Avatar
Go to a Chevy, Saturn or Pontiac dealer....now. They will have one.
Pierre
Old 08-24-2006, 05:04 PM
D4u2s0t's Avatar
if it didn't drip off the filter, and it's threaded properly, i would wipe off ALL the oil, turn the car on, let it run for a minute with the hood open, and see if it leaks... have you tried cleaning it off and seeing if it still leaks? just trying to cover the bases before you take it to the dealer...
Old 08-24-2006, 07:31 PM
johnkb8's Avatar
these 2 bolts have the only drips of oil? after i cleaned down there, i think this is the part that connects oil pan to transmission right..? (oil plug is to the right of picture if that helps... and transmission is to the left? right) well anyway it is these 2 bolts (says SAAB down there between em, lol), and they are tight, what the hell is going on, help!!
Old 08-24-2006, 07:57 PM
johnkb8's Avatar
bump, tryin to figure out what i should do and whats going on here
Old 08-24-2006, 08:06 PM
quad4racer's Avatar
replace cap even tho you cleaned it oil may have gone in some cracks and dripped out.
Old 08-24-2006, 08:14 PM
johnkb8's Avatar
the cap is way far away from these drips under the car
Old 08-25-2006, 09:08 AM
johnkb8's Avatar
bump, pictures in Post # 8, whats wrong there...?
Old 08-25-2006, 11:45 AM
D4u2s0t's Avatar
i'm a little disoriented here... were those pictures taken upside down?
Old 08-25-2006, 04:46 PM
johnkb8's Avatar
yes there were, upside i got under the front of car head first, upside down and took those pics
no_ss
10-18-2015 11:58 PM
importkiller
09-30-2015 07:18 PM
grampss
09-27-2015 08:51 PM
Adiaz1ss
09-26-2015 11:51 PM
09-26-2015 06:44 PM
Quick Reply: Oil Filter ? while i have a little oil leak...
