Oil leak from somewhere?
Old Dec 11, 2008 | 10:57 AM
PhantomSS's Avatar
It seems everytime i go hard in to my car it leaks a little bit. I've only had the dipstick pop out once and it seems the belt is slinging the oil mostly on the side of the block, a little on the top. Its a very small amount atm.
It usually happens after an oil change, 6.3 quarts go in, alot of oil is sprayed out until the dipstick hits 1/2 between min and max... then it doesnt do it nearly as much.
Anyone ever have this problem?
Old Dec 11, 2008 | 11:03 AM
lsjwannabe's Avatar
Do you have a catch can or oil breather.
Old Dec 11, 2008 | 11:05 AM
LS6Rally's Avatar
yea sounds like crankcase pressure is way to high.
Old Dec 11, 2008 | 11:08 AM
PhantomSS's Avatar
no, i dont
gah, what is the danger of running it how it is?
Old Dec 11, 2008 | 11:10 AM
lsjwannabe's Avatar
To much crank case pressure will blow the dipstick out from time to time, motors don't like loosing oil they prefer to keep it
Old Dec 11, 2008 | 11:12 AM
LS6Rally's Avatar
and if your really unlucky. you can blow the motor if there is to much pressure
Old Dec 11, 2008 | 11:18 AM
PhantomSS's Avatar
grrr
how would the motor blow short of losing oil? pop a ring?
lol agreed.
which works best? the catch can or the breather?
Old Dec 11, 2008 | 11:20 AM
lsjwannabe's Avatar
Take a look in the engine bay thread look at area47's car and quadracers or pauls turbo balt for that matter. They all have a decent setup.
GutterPalAl's Avatar
yeah, about that motor blowing, a seal would fail before the engine would, probably push crank seal out and **** oil out.
Old Dec 11, 2008 | 11:22 AM
lsjwannabe's Avatar
https://www.cobaltss.net/forums/show...111788&page=17
Old Dec 11, 2008 | 11:24 AM
PhantomSS's Avatar
ty lsj,
wtf can i get that oil return system?
Old Dec 11, 2008 | 11:26 AM
lsjwannabe's Avatar
I believe those are all custom parts to order, shoot him a pm i think he could help ya. If not a catch can itself is v ery simple and you could make one for $20 with parts from home depot
Old Dec 11, 2008 | 11:31 AM
PhantomSS's Avatar
lol i wasnt expecting adding more support mods and my head is being worked atm which is why im kinda in a bind atm. I have a friend who i can probably get his catch can from, he blew a hole in his cobalt's tranny casing doing a craptastic launch.
Old Dec 11, 2008 | 11:36 AM
lsjwannabe's Avatar
That sounds like a plan then, so get to it
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
