Oil question??
Update
Took the car in. The mechanic could not find the problem, so they are sending part of the engine off to GM. To have it pressure tested. Got a Pontiac G6 for a loner/rental ( all on GM). And all the repairs are covered under warranty.
possible resolution to oil problem
This foaming residue is a classic case of crankcase moisture. Your PVC valve may not be evacuating the crankcase, and the moisture is foaming in the oil. have the crankcase vent system checked and I think you will find your problem. Good luck, Ken.
update.
Called the dealership.
They (GM) is replacing the WHOLE engine. MR_Slobalt is a tech at the dealership that its at. He is going to do some P.I work and find out what went wrong.
importkiller
09-30-2015 07:18 PM
