Oil question??
Old 02-11-2008, 10:30 PM
silentgarth's Avatar
Oil question??
I checked the level of my oil the other day and found this on the end of the dip stick. By the looks of my pics does this mean I might have a leak in the head gasket?
I'm almost positive that is what it is but just would like some 2nd opinions.
Thank You.
Old 02-11-2008, 10:31 PM
DebadgedBALT77's Avatar
does look a little milky colored. cant tell for sure from here. you can always run a compression test to check for a bad head gasket.
Old 02-11-2008, 10:32 PM
chris88z24's Avatar
Did you take the oil cap off and look in there as well?
anthonyS88's Avatar
it does look like oil and coolant
TheDriver!'s Avatar
nasty!!
You just stuck that up your nose didn't you? no clue, what have you done or being doing to your car lately?
Old 02-11-2008, 11:42 PM
Havent done anything to the car. But here are some pics of the oil cap. It has the same residue on it.
Old 02-11-2008, 11:44 PM
redlineblueline's Avatar
that might just be foaming
Old 02-11-2008, 11:53 PM
chris88z24's Avatar
Coolant is mixing with the oil somehow. More than likely a head gasket and or craked engine block. Under warranty still?
Old 02-12-2008, 12:07 AM
yes it is.
Old 02-12-2008, 12:11 AM
chris88z24's Avatar
Originally Posted by silentgarth
yes it is.
Take it to a dealer and have them check it out. My guess is a headgasket.
Old 02-12-2008, 12:28 PM
Update
Took the car in. The mechanic could not find the problem, so they are sending part of the engine off to GM. To have it pressure tested. Got a Pontiac G6 for a loner/rental ( all on GM). And all the repairs are covered under warranty.
Old 02-13-2008, 11:19 PM
kclubepro's Avatar
Smile possible resolution to oil problem
This foaming residue is a classic case of crankcase moisture. Your PVC valve may not be evacuating the crankcase, and the moisture is foaming in the oil. have the crankcase vent system checked and I think you will find your problem. Good luck, Ken.
Old 02-27-2008, 02:02 PM
Exclamation update.
Called the dealership.
They (GM) is replacing the WHOLE engine. MR_Slobalt is a tech at the dealership that its at. He is going to do some P.I work and find out what went wrong.
DarrenGC
12-24-2021 01:55 PM
brandon04
10-21-2015 07:04 AM
717ssbalt
10-02-2015 04:01 PM
importkiller
09-30-2015 07:18 PM
dennis69
09-28-2015 02:16 PM
Quick Reply: Oil question??
