ok guys new CEL.
Old Jul 7, 2010 | 10:47 AM
SSinPA's Avatar
ok guys new CEL.
p0420 Catalyst System Efficiency Below Threshold (Bank 1). Does this mean my cat is dead? I have a Vibrant Downpipe with High Flow Cat. Any help?
Old Jul 7, 2010 | 11:06 AM
insylem's Avatar
Sounds like the cat to me,
They mad extended the warranty on it
so you should be good if you just take it
in they should swap it out for free.
Old Jul 7, 2010 | 11:21 AM
SSinPA's Avatar
its an aftermarket cat so they won't cover it. Its a high flow cat but the system has been on for over a year with nothing and now it throws this code. I can clear it with a scan tool and it will stay off for a little while but will come back on. O2 sensors maybe?
Old Jul 7, 2010 | 11:29 AM
coopercharge's Avatar
Just use a spark defouler sometimes high flow cats with throw codes. You have 3 options.
1. Just leave it CEL sucks though.
2. Get it tuned out and this can be farely cheap just get the 99 ZZP PCM Tune they will tune that code out for you.
3. A spark plug defouler will meter the air that hits the O2 sensor this had about a 95% effective rating.
Old Jul 7, 2010 | 10:42 PM
army_greywolf's Avatar
Nvm, saw the post before mine. Yes a spark plug defouler OR whats also called 02 sensor housing extension.
Old Jul 8, 2010 | 01:40 PM
SSinPA's Avatar
Front o2 sensor or rear?
Old Jul 8, 2010 | 01:43 PM
05Slowline's Avatar
It's the front 02 sensor, are you tuned? Can just delete the code.
If the cat was fucked it'd prob throw lean bank codes and ****.
Old Jul 8, 2010 | 02:59 PM
P0420 is Catalyst Below Efficiency its the rear O2 Sensor it the sensor that lets you know the cat is not working properly.
This is the rear O2 Sensor that putting off the code.
Last edited by coopercharge; Jul 8, 2010 at 02:59 PM. Reason: Automerged Doublepost
Old Jul 8, 2010 | 03:02 PM
05Slowline's Avatar
Yeah you're right. multitasking fail lol
Old Jul 8, 2010 | 03:06 PM
I know how it goes mind is on one thing typing another. I must do that about 20 times a day at work.
Old Jul 9, 2010 | 08:54 AM
SSinPA's Avatar
I thought the rear was there to determine a difference between the front and rear. The rear should show smooth patterns and the front should have a rough pattern. If the front is faulty it would show not a whole lot of difference which would make it seem the cat is not efficient. So shouldn't the front u2 be bad?
Old Jul 9, 2010 | 08:56 AM
05Slowline's Avatar
Nope po420 means that the rear isn't reading correctly in comparison to what the front is reading
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
roth
Sep 26, 2015 12:16 PM
