One of the Accessory Outlets Will Not Work!
Just wondering if anyone else has had this problem. My accessory outlet that is just under my HVAC controls has no power going to it.
I guess I have two questions.
1. How hard is it to get behind the outlet to see if it is Just not connected.
2. How easy would it be to get the dealer to replace this if it isn't a connection problem.
Thanks
Thanks
I will have to take a look. I think it has been this way from the factory which leads me to believe that the fuse may be ok. I will look at it tomorrow if the weather is good. Does anyone have a link to a wiring diagram for the fuse block so I can figure out which fuse that I am looking for?
nevermind... I found where the fuse box and diagram is... lol search button lol
yeah look at that first... If you end up taking a look at the plug, take off the plasic around the ebrake first, then unscrew the boot from your shift knob, remove the knob, then remove the plasic around the shifter (cupholders and all). The only thing holding this piece to the car are the connections to both the 12V plugs.
Hopefully it is just a blown fuse. GL Rory lol
That fuse for the cigarette lighter is in the engine bay. It also powers the OBDII port. The accessory outlet near the E Brake is in the interior fuse panel.
For the cig lighter, look for a fuse in the engine bay called "LTR". 20a IIRC
pull the trim from around the ebrake
pull the ebrake boot up
pull the whole thing out and check the connection
i blv its actually a 15, i know its blue...
ive popped mine many a time from accidently letting tapped off stuff touch :P
Last edited by NWAE Cobalt; Aug 5, 2009 at 08:02 PM. Reason: Automerged Doublepost
I found the problem for mine a little while ago. It was the 15A fuse that is under the hood like WickedSS2005 had mentioned. As they have mentioned above. the two accessory outlets are on two different fuses.
same thing happened to mine when i used a tire compressor in the forward outlet when my car was off.
the fuse did not like that at all. took me 2 weeks to figure out what LTR meant cause i couldn't find the owners manual. lol
