One of the Accessory Outlets Will Not Work!
Old Aug 4, 2009 | 11:20 PM
SKCobalt's Avatar
Just wondering if anyone else has had this problem. My accessory outlet that is just under my HVAC controls has no power going to it.
I guess I have two questions.
1. How hard is it to get behind the outlet to see if it is Just not connected.
2. How easy would it be to get the dealer to replace this if it isn't a connection problem.
Thanks
Old Aug 4, 2009 | 11:38 PM
bmb17's Avatar
I think you can just pull all the trim off around the radio and pull the hvac out and see if its hooked up. There is a how to on how to pull all the trim off. Did you check fuses?
Old Aug 4, 2009 | 11:58 PM
jschatte's Avatar
yeah it all comes off without any tools. Just pull away. But before you take it all apart did you check the fuses?
Old Aug 5, 2009 | 01:05 AM
SKCobalt's Avatar
I will have to take a look. I think it has been this way from the factory which leads me to believe that the fuse may be ok. I will look at it tomorrow if the weather is good. Does anyone have a link to a wiring diagram for the fuse block so I can figure out which fuse that I am looking for?
nevermind... I found where the fuse box and diagram is... lol search button lol
Old Aug 5, 2009 | 01:09 AM
jschatte's Avatar
yeah look at that first... If you end up taking a look at the plug, take off the plasic around the ebrake first, then unscrew the boot from your shift knob, remove the knob, then remove the plasic around the shifter (cupholders and all). The only thing holding this piece to the car are the connections to both the 12V plugs.
Hopefully it is just a blown fuse. GL Rory lol
Old Aug 5, 2009 | 06:39 AM
WickedSS2005's Avatar
That fuse for the cigarette lighter is in the engine bay. It also powers the OBDII port. The accessory outlet near the E Brake is in the interior fuse panel.
For the cig lighter, look for a fuse in the engine bay called "LTR". 20a IIRC
Old Aug 5, 2009 | 09:51 AM
SKCobalt's Avatar
Thanks Wicked
Old Aug 5, 2009 | 08:00 PM
papasmurf's Avatar
Yea, check your fuses. I had a cell phone charger that for my car and one day I plugged it up ( car was only 3 or 4 months old) and popped the fuse.
Old Aug 5, 2009 | 08:02 PM
NWAE Cobalt's Avatar
pull the trim from around the ebrake
pull the ebrake boot up
pull the whole thing out and check the connection
i blv its actually a 15, i know its blue...
ive popped mine many a time from accidently letting tapped off stuff touch :P
Last edited by NWAE Cobalt; Aug 5, 2009 at 08:02 PM. Reason: Automerged Doublepost
Old Aug 6, 2009 | 12:44 PM
Originally Posted by SKCobalt
Thanks Wicked
No probelm.
It may be a 15a like NWAE said, but w/e it is, follow my steps and replace with corresponding fuse
Old Aug 15, 2009 | 11:52 PM
seekNdestroy's Avatar
Same prob here then one day it started workin, I was confused to y it had 2 outlets an only 1 worked, then I dunno wha happened it started workin
Old Aug 17, 2009 | 01:29 PM
SKCobalt's Avatar
I found the problem for mine a little while ago. It was the 15A fuse that is under the hood like WickedSS2005 had mentioned. As they have mentioned above. the two accessory outlets are on two different fuses.
Old Aug 17, 2009 | 09:18 PM
jschatte's Avatar
Geez those engineers are idiots!
Old Aug 17, 2009 | 11:45 PM
SKCobalt's Avatar
Hey,,, lol! I had a plan! I was going to completely disassemble the car and put it back together and hope that that solved it!
Old Aug 17, 2009 | 11:55 PM
jschatte's Avatar
hahaha
Old Aug 28, 2009 | 06:03 PM
blackbolt89's Avatar
same thing happened to mine when i used a tire compressor in the forward outlet when my car was off.
the fuse did not like that at all. took me 2 weeks to figure out what LTR meant cause i couldn't find the owners manual. lol
RaginChopsuey
Oct 27, 2015 01:27 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
grampss
Sep 27, 2015 08:51 PM
