P0017 code help please
Old Feb 8, 2011 | 08:51 PM
startingline05's Avatar
i installed my new timing chain tensioner this weekend and when i did the chain jumped on me. not knowing at the time it did. when i installed everything i went for a drive and first of all the car idled horrible. when i drove my iat2's would jump up real high then go back down alot. so now i have my valve cover off and my engine at TDC. my question is where are the marks on the cam gears suppose to be?
Old Feb 8, 2011 | 08:59 PM
SunburstSS's Avatar
I'm sorry what you mean by your chain jumped on you ? I replaced mine like 2 months ago with no problems, did you turn the car on before or while installing the tensioner ? and is it torqued well ?
Old Feb 8, 2011 | 09:06 PM
well i dont know if the chain jumped. i had the valve cover off when i did the install and when i took out the old tensioner it just moved really quick, when it got lose. i have valve cover off again and i was looking at the pink chain link. is it suppose to be on either the line on the exh cam gear or the intake cam gear? also when i was turning my crank it was pretty easy to turn besides at certain times during the rotation it was alittle harder to turn then normal
Old Feb 9, 2011 | 08:34 AM
i called the dealership and the price is alittle less the 200 dollars to fix the timing, if i didnt bent any valves. how would i know if i have bent a valve? would you hear it?
Old Feb 9, 2011 | 02:38 PM
5hizn1t's Avatar
Talking
Look HERE for the installation instructions. It will have the timing marks and show how to line everything up.
Old Feb 9, 2011 | 03:37 PM
awesome, these instructions make things 10 times easier that what it seems. is there anyways you can send me a link to the camshaft cover replacement and the engine front cover replacement?
Old Feb 9, 2011 | 04:39 PM
5hizn1t's Avatar
will try.... give me an sec
How about:
FRONT COVER REPLACEMENT
CAM COVER REPLACEMENT
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
