P0106 code
Old Sep 15, 2008 | 06:06 PM
CobaltDude06's Avatar
P0106 code
my car just threw p0106 map sensor i searched and couldnt find anything. What could be causing it to throw this i think it make be the hose that connects my cai to the valve cover cause its starting to come apart and i need to repleace just curious as to what all of yall think thanks.
anybody ?????????
20 views and nobody knows what may have caused this other than what i have said
Last edited by CobaltDude06; Sep 15, 2008 at 06:06 PM. Reason: Automerged Doublepost
Old Sep 15, 2008 | 07:00 PM
Coblasts's Avatar
From what im reading any intake vac leak will cause that code,So yes fix that hose and erase the code again and see what happens.
• The PCM detects that the MAP sensor signal is 25 kPa more than the calibrated estimate for more than 90 seconds. OR
• The PCM detects that the MAP sensor signal is 45 kPa less than the calibrated estimate for more than 90 seconds.
Inspect for the following conditions:
• Any disconnected, damaged, or incorrectly routed vacuum hoses
• Any damage or fractures to the manifold absolute pressure (MAP) sensor housing
• A missing or damaged MAP sensor seal
• Restrictions or debris in the MAP sensor vacuum port
• An Intake manifold vacuum leak
Old Sep 15, 2008 | 08:03 PM
thank you so much man i figured thats what it was now i just need like 3 dollars to go get a piece of new hose which i should have tommorrow lol
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
