P1682 Cobalt SS 2.4 2006
Old Aug 13, 2012 | 10:53 PM
Twoozofjuice's Avatar
Anyone know what the code means? Hpt gives me 2 codes that are the same
p1682 Driver 5 line 2 (SES) (History) (Immature)
and
I looked at the DTC thread and that code says
P1682 Ignition 1 Switch Circuit 2 ECM, PCM
I'm also getting P0575 Cruise Control Related Malfunction
Wondering if that ^ is from putting in a aftermarket radio and having the buttons from my steering wheel not working. Well i know the volume ones aren't supposed to work or something but the cruise control doesn't work either which doesn't bother me much since i never use it anyways
Old Aug 14, 2012 | 12:07 AM
bumpp
Old Aug 14, 2012 | 12:21 AM
OttawaMark's Avatar
it means the 2 reference voltages used by the pcm are not the same. I got this when I ran my IC pump off the ABS power wire as ZZP suggested. In short, you are drawing too much power off a circuit somewhere and the PCM sees it as the difference between the 2 references.
Old Aug 14, 2012 | 12:23 AM
perfect thats exactly whats happening to my car then. I am running my IC pump off the ABS power wire just how it said in their instructions. Where did you switch it to?
Old Aug 14, 2012 | 04:46 PM
OttawaMark's Avatar
Ran it off the spare key-on fuse in the underhood fuse box, there is another key-on spare in cab on the passenger side center console panel as well.
Old Sep 23, 2012 | 07:20 PM
buuump...changed the wiring to the reverse lights or something like that and I still get the code after having reset it. anyone have any other ideas
Old Sep 23, 2012 | 07:40 PM
Pedobear's Avatar
needing constant power? im a little out of the game but have you thought about the sunroof fuse or windshield wiper
Old Sep 23, 2012 | 07:42 PM
I has no sunroof. Would the wiper work? I know I tried the wiper with my boost gauge and it stayed on even when there wasnt a key in the ignition so i figured it would be the same here...also james told me that I need to run it off a 30+ amp thing or something like that so idk...ill try out wipers though and see if that works.
Old Sep 23, 2012 | 08:07 PM
bluebalt07's Avatar
I get both these codes randomly from time to time. Never seems to affect anything but I have no idea what causes them.
Old Sep 23, 2012 | 08:08 PM
yeah im getting them too and they dont really make a difference with anything but james wants me to find out why they are coming on and fix it.
Old Sep 23, 2012 | 09:24 PM
Pedobear's Avatar
even tho you dont have a sunroof the wiring in the fuse box should still be "hot" even tho there isnt a fuse in. get an appropriate fuse and give it a shot.
Old Sep 23, 2012 | 09:25 PM
what does that last part mean? what is an appropiate fuse...i get confused with wiring and electrical stuff on cars :/
Old Sep 23, 2012 | 09:30 PM
Pedobear's Avatar
i mean like if it calls for a 10 use a 10 the diagram on the box cover will tell you
Old Sep 23, 2012 | 09:34 PM
Ok i have 3 things wired to my engine fuse box. my afr gauge and boost gauge. both wired to uhhh fog lights and i put a larger fuse into it....might be a problem idk lol. I also have the ic pump wired to the reverse lights with the regular fuse in it. these are all addons so they dont have designated fuses. which should they be wired to? thanks for the help
Old Sep 23, 2012 | 09:40 PM
Pedobear's Avatar
i would replace that fog light fuse with its normal one and move either boost or afr to another source.
Old Sep 23, 2012 | 09:41 PM
ill look for something else to wire into thanks. maybe lighter fuse
WhineSSbaby
Sep 1, 2020 12:39 PM
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
satisfied
Oct 19, 2015 12:35 AM
lsjunior
Sep 4, 2015 10:23 PM
