P2187 (I think I see the fix)
Old Mar 17, 2010 | 11:31 PM
Scythe_Snake's Avatar
Well I was driving home today and I got a P2187 "engine too lean at idle" like everyone else has been getting. I was just cruising around 65 on the express way on the way home. I researched and checked pass threads and I think I see the problem I just need to know if I'm correct or not:
I forget how its supposed to look but I don't think its supposed to be this far off, is it?:
Hard Parrt Mods:
Full hahn bolt ons basically
any one got any answers?
Last edited by Scythe_Snake; Mar 17, 2010 at 11:31 PM. Reason: Automerged Doublepost
Old Mar 18, 2010 | 12:05 AM
mkriebs's Avatar
No, I don't think thats it, really. Does it just pull off as it sits? My guess is its boost leak on the IC pipes.
Old Mar 18, 2010 | 12:20 AM
Would the boost leak cause a lean code though? Its loose as it sits.I will check the pipes tomorrow.
Old Mar 18, 2010 | 12:26 AM
IdreamofYenko's Avatar
No a boost leak causes a rich code. If it were that you would be getting P2178 like I did which would fry a $70 O2 sensor like mine did. No idea on yours though.
Old Mar 18, 2010 | 12:31 AM
mkriebs's Avatar
Not necessarily. At idle, a boost leak could cause it to run lean. You know... not EVERY instance is going to be EXACTLY like what you have experienced.
Old Mar 18, 2010 | 02:07 AM
Yeah very true.
Old Mar 18, 2010 | 02:10 AM
I will test for a boost leak or two tomorrow as well as tighten everything up. If anyone has anything in dealing with the intake, lemme know.
Old Mar 18, 2010 | 02:15 AM
PRND3L's Avatar
just put a tampon on it, im sure that will fix it!
Old Mar 18, 2010 | 02:42 AM
mkriebs's Avatar
It could possibly be that connection, you are right, but if its tight, i don't think it is. The space its 'off' is prolly due to the size of connection they used. Its just a fuel line connection, basically. If you don't find a boost leak, you could try sealing the connection up with some RTV sealant. If THATS not it, then I would change out the front O2 sensor.
What tune are your running?
Old Mar 18, 2010 | 11:28 AM
Trifecta switchable tune right now. So the tune is currently on the stock one when the CEL came on.
of course it will!
Anyone else got any chimes in?
Last edited by Scythe_Snake; Mar 18, 2010 at 11:28 AM. Reason: Automerged Doublepost
Old Mar 18, 2010 | 05:14 PM
mkriebs's Avatar
You running a vta (vent to atmosphere) BOV? That will cause it.
Old Mar 18, 2010 | 08:00 PM
LOUD SS/SC's Avatar
if i know ryan correctly he dont use bov's
Old Mar 18, 2010 | 10:23 PM
mkriebs's Avatar
I didn't figure he is, but just worth asking.
Old Mar 18, 2010 | 11:49 PM
Nope. using stock one. =)
Old Mar 19, 2010 | 12:01 AM
mkriebs's Avatar
K, thats what I thought. Did you check your boost tubing? Might check your MAP sensor lines too, when you did your IC pipes, you may have accidentally popped one off, or not got it on fully.
turbochargedss2012
Sep 20, 2023 12:17 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
