Passenger Side Rattle SOLVED!
Old Oct 23, 2010 | 11:01 AM
Dodgetweaker's Avatar
I saw a very old post about a rattle on the passenger side of the car. I have the same problem and found the source so I decided to contribute to the knowledge center of the forums (I have been taking a lot lately and now I can give back!).
Problem:
Plastic sounding rattle from the passenger seat area. Sounds like it is coming from the passenger door.
Source:
The rattling is coming from the passenger seat fore/aft adjustment handle. The handle has slop in the seat attachment pivot point. This rattles and causes the plastic trim on the seat to vibrate. When I hold the handle, the sounds stops.
Solution:
Not sure. I need to find out how to insert some kind of bushing between the hole on the handle and the shaft on the seat or add a spring to preload the joint.
Old Oct 23, 2010 | 11:05 AM
Empty Pockets's Avatar
i'll have to check that out bc i have some sort or rattle coming from the passenger side too
Old Oct 23, 2010 | 11:08 AM
Dart_SI's Avatar
ive decided im just going to go thru my car and tighten down any things that look like they might come loose. im not a fan of rattles.
Old Oct 24, 2010 | 12:04 AM
06'Yellow SS/SC's Avatar
This ^^^
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
