Please Help! Salvage car repair my dad and I just started
Old Sep 22, 2010 | 09:56 AM
LARGEsuperchargeSSSC's Avatar
Originally Posted by Coblasts
We need a little more info,
1)does the engine turn over(clutch switch not making,see #3)
2)If not do you hear the starter clicking(battery could be drained,try boosting the battery or charging it)
3)If not is the security light illuminated in the dash(Sometime it needs to be reprogramed due to battery disconnection)
Okay, this is what is happening when I start the car. I'll sit down, hit the clutch and turn the ignition. The car will start, but it cranks for a while. It is very hard to start. Once it finally turn over it idles good. There is no problem with the idling. However, once I go to give it gas, there is no power in the gas pedal. Maybe a sensor or fuel pump??? The car has around 68,000 miles on it, too. Thanks again fellas.
Old Sep 22, 2010 | 10:45 AM
rnjmur's Avatar
Sounds like a fuel or spark problem, but I would lean toward a fueling problem. Check your fuel pressure (there is a check valve at the fuel rail) and make sure you are seeing the correct pressure. I believe it should be at 60 psi. If fuel pressure is low it *could* be a fuel filter, but more than likely you may need to replace the fuel pump.
Old Sep 23, 2010 | 08:01 AM
Coblasts's Avatar
Could be a cam or crank sensor.
Check the wiring to these for damage.
Do a search of the form !I've read a few with similar sceniario.
Old Sep 23, 2010 | 11:53 AM
Okay thanks. I misunderstood when my father told me, but the car will rev or rpm's will go up when you hit the gas is the car is on. It just doesn't feel right. And it takes a while to turn over after you turn the ignition. Any other suggestions?
hawkssoccer11
Sep 30, 2015 12:14 PM
Wind
Sep 11, 2015 06:57 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
