Possible Boost surge?
Old Jan 14, 2007 | 04:18 AM
05redline's Avatar
Ok I have noticed this for quite a while now on my car. Whenever I am harder on the throttle compared to normal driving and hit around 3,500 RPMs in 3rd gear, the car has a sudden jerk or kick to it. Then all of the sudden it seems to start to pull a lot harder. I have not had this happen in any other gear or RPM. Usually the power is smooth throughout the rev range on hard throttle runs.
Do you all experience the same thing, or is this something I should have looked at? Is this something that the newer PCM calibration updates fix
Old Jan 14, 2007 | 04:21 AM
c0ld29's Avatar
I don't believe my car does that... 3rd is normally smooth all the way
Old Jan 14, 2007 | 04:23 AM
NJHK's Avatar
What upgrades do you have?
Old Jan 14, 2007 | 05:45 PM
05redline's Avatar
100% stock
Old Jan 14, 2007 | 06:54 PM
NJHK's Avatar
I honestly don't know...
Old Jan 14, 2007 | 07:02 PM
1BadBlueSS's Avatar
have you had the software update from the dealer yet?
Old Jan 14, 2007 | 07:05 PM
patathSS's Avatar
V-tak....
or its where the PE tables are set to kick in. Stock I think the PE enable RPM is 3600.
Old Jan 14, 2007 | 08:21 PM
05redline's Avatar
Not that I know of.
I'm sure the dealer will not give me the newer calibration just on this occurance. What else should I tell them is going on so that they will put the update on? From what I've heard they will do it only if the idle bounces or cetain codes are set, but then again that's hearsay.
Originally Posted by patathSS
V-tak....
PE tables? I'm lost there, what's that?
Old Jan 14, 2007 | 08:27 PM
patathSS's Avatar
Power Enrichment, its the table used to add fuel when you are WOT. On my stock tune the delay is set to 3850 RPM so below that power enrichment won't come on right away.
Old Jan 14, 2007 | 08:31 PM
Witt's Avatar
I think it's set at 3850 on stock tune and 3600 on staged ones.
(P)ower (E)nrichment is a fuel enrichment that enables when 3 parameters are met. RPM is one of them. PCM adjusts metered fuel to accomplish a richer burn than 14.7-1 to slightly increase power, cool pistons, and quench possible knock.
Edit: Pat posted faster than me. :P
05redline's Avatar
Is the power enrichment supposed to be noticeable while driving? I could be running hard throttle from first, but when I reach the 3,500 mark in 3rd I can feel it.
I guess I'll take it in and see what they can do.
Old Jan 14, 2007 | 08:34 PM
Witt's Avatar
They won't be able to adjust it for anything that deviates from the stock tune. Find someone in your area that owns HPTuners, and they will be able to lower it for you. However it is a normal occurance on any GM calibration.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
