possible oil leak
Old Oct 16, 2009 | 12:49 PM
Mike08ss/tc's Avatar
possible oil leak
I check my oil everyday before driving. I started to notice that there was oil behind my oil filter cap. It is collecting in the 2 holes behind it. Not sure what it is. need help.
https://www.cobaltss.net/gallery/fil...downsize_1.jpg
Old Oct 16, 2009 | 01:58 PM
fakameanrepresent's Avatar
could be the infamous head leak on our LNF.
Old Oct 16, 2009 | 02:44 PM
great. i will sell that so fast it wont be real. it is prolly those shitty ass gaskets they put on
Old Oct 16, 2009 | 02:54 PM
Cobalt_Daddy's Avatar
ya i don't think it's a major issue... take it in if it's still under warranty. if it's not get it checked and quoted to see if it costs much to replace the gasket...
Old Oct 17, 2009 | 03:58 AM
Mike85220's Avatar
My wife's 2.2 Ecotec Sunfire had the same thing.
It was the oil filter tower.
The screw on cap has a cheap gasket and if you over torque it, the thing gives a slow leak.
I let it go for a long time...
I have a new cap and it never leaked since.
Old Oct 17, 2009 | 11:26 AM
i am prolly going to bring it in. see if they are going to void my warranty.
that is what i was thinking. i want to say it is that. i never started noticing it until after i changed my oil. i got a problem with over torquing things
Last edited by Mike08ss/tc; Oct 17, 2009 at 11:26 AM. Reason: Automerged Doublepost
Old Oct 18, 2009 | 12:28 AM
Mr_Slobalt's Avatar
I've seen more than a few leak from the o-ring....not a huge deal man
Old Oct 25, 2009 | 04:01 PM
Collin's SS's Avatar
it is the o-ring on the oil filter cap, K @ N oil filters come with a new o-ring. change that o-ring EVERY time you change your oil, and it will never leak agean!!
Old Oct 25, 2009 | 09:37 PM
i change t everytime. i think i know what it is.
Old Sep 30, 2012 | 03:18 PM
adiovolcomskater's Avatar
Did you find out what this issue is? My car is leaking oil really bad from behind the oil filter housing.
Old Sep 30, 2012 | 08:05 PM
rukkee's Avatar
It might be the High pressure fuel pump leak ..... I'll have to look again but isnt the HPFP sitting above those holes?
Here is the TSB from GM
#09-06-01-014: Oil Leak by High Pressure Fuel Pump (Reseal Camshaft Cap) - (Dec 3, 2009)
Subject: Oil Leak by High Pressure Fuel Pump (Reseal Camshaft Cap)
Models: 2007-2009 Chevrolet Cobalt SS, HHR SS
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
Equipped with a RPO LNF Engine
Please Refer to GMVIS
Condition
Some customers may comment on an oil leak.
Upon further investigation, a technician may find oil leaking from the high pressure fuel pump area.
Cause
This condition may be caused by a camshaft cap that is not sealed correctly to the cylinder head, causing oil to leak out.
Correction
•Verify the customer's concern.
•Remove the fuel pump. Refer to Fuel Pump Removal in SI.
•Remove the camshaft cover. Refer to Camshaft Cover Removal in SI.
•Remove the camshaft cap (1). Remove all excess sealing material from both surfaces.
Note: It is critical during installation to ensure the bearing rear cap and cylinder head alignment is correct and the mating surfaces are flush.
• Ensure that all sealing material has been removed from the components and the sealing surfaces are clean and free of contamination prior to applying the sealer.
• Install and align the rear cap within 20 minutes of applying the sealer.
•Apply a 2.5 mm (0.1 in) bead of sealer, GM P/N 12378521 (in Canada, use P/N 88901148) to the cylinder head at the number 6 intake camshaft rear cap mating surface.
Note: Apply the sealer to all locations centrally locating the bead on the rail.
• Run the bead to 5 mm (0.2 in), dimension "a", as shown.
• Where the cap ends on the perimeter rail, extend bead approximately 4 mm (0.2 in) beyond edge of cap.
• Run bead, dimension "c", 32 mm (1.3 in) from the edge of the cylinder head as shown.
• Run bead, dimension "b", 20 mm (0.8 in) from edge of cylinder head as shown.
•Install the number 6 intake camshaft rear cap.
6.1. Tighten the cap bolts evenly to 5 N·m(44 lb in).
6.2. Tighten the cap bolts evenly to 10 N·m(89 lb in).
6.3. Back the cap bolts out 120 degrees.
6.4. Tighten the cap bolts evenly a final pass to 10 N·m(89 lb in).
•Install the camshaft cover and gasket, GM P/N 12609291. Refer to Camshaft Cover Installation in SI.
•Install the fuel pump. Refer to Fuel Pump Installation in SI.
Important: When installing the fuel pump, install a NEW high pressure fuel pump O-ring (GM P/N 12600313), high pressure fuel pump gasket-to-cylinder head (GM P/N12595951) and high pressure fuel pipe (GM P/N12615401).
Parts Information
Part Number
Description
12609291
Camshaft Cover Gasket
12595951
Gasket, High Pressure Fuel Pump Gasket
12600313
High Pressure Fuel Pump O-Ring
12615401
High Pressure Fuel Pipe
12378521 (U.S.)
88901148 (Canada)
Silicone
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J7549*
Reseal Camshaft Cap
2.6 hrs
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
