Purge/Vent Solenoid Question
Old Nov 11, 2009 | 08:45 PM
RickyD's Avatar
Will the purge/vent solenoid cause no fuel pressure? Everything seems to be working (fuel pump) so im wondering if one of these solenoid could be the culprit. Any help would be appreciated. Thanks.
Old Nov 11, 2009 | 08:48 PM
slowswap's Avatar
You didn't say what your problem is. From my experience, purge vent solenoid has nothing to do with fuel pressure.
Old Nov 11, 2009 | 08:50 PM
NVMYCOBALTSS's Avatar
the purge should be plumbed in line before the N2o solenoid. It doesn't have anything to do with fuel pressure.
Old Nov 11, 2009 | 08:56 PM
RickyD's Avatar
I have no fuel pressure at the schrader valve. Fuel pump comes on, new fuel filter, fuel circulates through the fuel filter, but still no fuel pressure.
Old Nov 11, 2009 | 08:58 PM
slowswap's Avatar
You have no idea what you're talking about. He's referencing the EVAP system.
Does your pressure gauge have a pin to depress the schrader valve so it can read pressure?
Old Nov 11, 2009 | 09:14 PM
RickyD's Avatar
Since I was out of ideas of why i'm not getting fuel to the injectors I was thinking the EVAP system could have something to do with it, but I now know it has nothing to do with pressure.
Yeah the gauge does. Doesn't even get a reading. I hear the fuel pump working, even tested the voltage and it appears to be ok. 11.53 volts.
Old Nov 11, 2009 | 09:20 PM
JapEatr's Avatar
South Central *********
the pump can have power, turn on, and yet still have no fuel pressure
$100 bux says its the fuel pump
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
yellow dragon
Sep 28, 2015 09:49 PM
