Q for those with HIDs.
Old Jul 3, 2006 | 12:52 AM
Ljavy17's Avatar
I have a set of 10k on my headlights and in my fogs, However just recently my driver side headlight started a constant flickering, its really weir is like it keeps turning on and off constantly like really really fast, I have turn it off for a few seconds and then back on it wont happen for a lil bit but it always comes back, does this mean my bulb has gone foul or what. Im pissed. everytime I get closer to boosting 20lbs, something breaks. whats do you guys think this is.
Old Jul 3, 2006 | 12:53 AM
DC52NV's Avatar
i think you should get a set of 4300k HID's. 10000k is just rediculous. hope you don't drive in the nighttime when it rains.
check to see all the conections are tight.
Old Jul 3, 2006 | 12:54 AM
HackAbuse's Avatar
And sell the 10k to Hack
Old Jul 3, 2006 | 12:56 AM
Ljavy17's Avatar
their actually 8k im sorry, like bluish and I used to get the high beams all the time and even got cuzzed out once and had to pull my baseball bat out but, I leveled them and havent gotten the high beams anymore, lol. So DC you think is the connections.
Old Jul 3, 2006 | 12:57 AM
06black's Avatar
hmmm....to me it sounds like the ballist inst geting good power any more.
when a HID bulb goes bad it wont flicker...it'll simply blow out upon start up when the voltige is higher(had it happen to me)....i would go around and check all your wireing...then contact who ever you got them from and see if you might be able to get an answer from them...maybe replace the ballist???
Old Jul 3, 2006 | 01:05 AM
DC52NV's Avatar
might also want to check your ground wire. it could be your ballast though. if you can, switch out your ballast and see if it does the same thing on the other side.
Old Jul 4, 2006 | 12:57 AM
TWIZTED 2.2's Avatar
does anyone know what buld comes in the Fog lamps stock?
Old Jul 4, 2006 | 01:02 AM
HackAbuse's Avatar
H11 type bulbs
Old Jul 7, 2006 | 04:48 PM
Ljavy17's Avatar
Update. I temporarly fixed the problem by turning off and back on the headlights. Now it doesnt flicker anymore but it turned freaking weak green! it looks soo uneven, one of them is weak green and the other one a powerful blue. WHAT NOW
Old Jul 7, 2006 | 05:03 PM
SS_SC_Cobalt's Avatar
sounds like the ballast, do you have them wired to the stock harness or thru a seperate relay harness?
Old Jul 7, 2006 | 05:57 PM
Ljavy17's Avatar
no relay, just thro the stock harness.
CobaltSS 16
Jun 9, 2010 07:51 AM
Spanky's Monkey
Mid Central
Oct 11, 2009 10:35 AM
CudaJoe
Sep 12, 2009 11:02 AM
jlong3382
Oct 15, 2008 02:22 PM
