road noise
Your driver's side weatherstripping may be pinched funny or come loose.
Also check to make sure your window is up all the way.
ears do pop alot like im in a vaccum in this car
Mine does the same thing. I think it's got something to do with my weather stripping...at least that's what my boyfriend said when he drove it. Nothing to do with the tires, it's all the weather stripping, at least mine is anyhow.
hey anybody is there a tsb for wheterstriping
First off just make sure it all looks good and that it's straight. There are ways they can check for leaks for you at the dealership as well, if you don't want to deal with it.
im going to have them check that and the wheel bearing and also go to different dealer to fix my f.........ing clunk in my front end when driving slow over rough roads lol to sterring gears two colums shaft and strut and rack and they still cant fix it
Or you can do what they do on all the TV car shows, and put a dollar bill in the jamb and shut the car door. Then with the window down try to wiggle it up and down along the weatherstripping. I don't know if it really works and there are defintely better ways to test for leaks with smoke and stuff, but it's real simple.
It could be the weatherstripping, and it could also be the alignment of your door. So it seems like the whole thing isn't closing correctly, or does it seem like the sound is just coming from one spot?
ok the sound is like when you hear a plane off in the distance or likw a whirling wind like its coming from the left front tire
well if my ears are popping in side this car then whount that mean that its sealed good or to good
Edit: You should take it to the dealership.
Like the G6, our mirrors cause alot of wind noise. I noticed this in my bro's car(G6) and when I purchased mine. Anytime you get above 60 when I start to hear it and increases with speed. It's even worse with the radio off, just turn up the music.
If your ears are poping then you might have an leak somewhere. Unless you are changeing altitude and/or opening or closeing the windows or sun roof, then it's normal.
DANRICKARD
Oct 1, 2015 12:08 AM
