Rough, cammy sounding idle
Old Oct 12, 2010 | 02:37 AM
a_joyner's Avatar
So, I have an intermittent rough idle. It will idle fine for a few seconds, then it almost sounds like it has a cam in it, like.............blub, blub, blub...................blub, blub..............I've already put new plugs in, that didn't help...gapped them tighter (.035) and it still does it. I recently had a stage 2 put on and a new fuel filter.....it did it before I put that stuff on and none of that changed anything, so I don't think it's a fuel problem. I checked for vacuum leaks and didn't find any....replaced a hose that was rough looking. I also tried cleaning the throttle body and MAF......didn't help. I'm thinking it might be one of the coil packs? I've never gotten any cel's though. Any suggestions?...this is driving me crazy....especially when I'm sitting in traffic in a car with only 45k on it, and it's idling like a piece of junk. The spark plugs I am using are Champion 7546's....it's a double platinum plug.....could these plugs be causing a problem?
Old Oct 12, 2010 | 08:14 AM
HyperMuffin's Avatar
Check again for vacuum leaks. Mine sounded like it was cammed and idled like **** when I had a vacuum leak because my intake mani wasn't bolted down all the way.
Old Oct 12, 2010 | 08:15 AM
Kyle4236's Avatar
my friend with a SC and gms2 sounds like that whenever he idles with his AC on
Old Oct 12, 2010 | 08:25 AM
Gunney_07's Avatar
i have an lnf and mine does this, intermittently as well. I've replace front o2, purge valve, plugs, checked hoses for vacuum/boost leak. I cannot figure it out either, it doesn't hurt me performance wise, just sounds funny.
Old Oct 12, 2010 | 08:39 AM
a_joyner's Avatar
I'm gonna go to autozone today and see if any codes are popping....if it's a misfire it should be logged.....I've never had the mani off, but that's still a possiblity...I might just replace the intake gasket.
Old Oct 12, 2010 | 08:45 AM
RoadconeTuning's Avatar
mine LNF does it from time to time, usually a few revs to 2500 or so clears it up.... or turning it off then back on. i think its the ecu wigging out and dumping too much fuel
Old Oct 12, 2010 | 08:47 AM
coopercharge's Avatar
Most of the time with the stage 2 and up it will do this what you need to do is pull the throttlebody off and clean with tb cleaner then spray some on a rag and clean the supercharger inlet. Mine was doing the same thing and this fixed it.
Old Oct 12, 2010 | 08:52 AM
a_joyner's Avatar
Mine is fine if I rev it, but goes right back to idling rough. I hope it's not something major.
Old Oct 12, 2010 | 08:55 AM
a_joyner's Avatar
I already tried cleaning the throttlebody....from what I understand that fix is to stop the surging idle....mine sounds more like a misfire.
Old Oct 12, 2010 | 12:35 PM
my guess is dirty/sticking injector.
Old Oct 12, 2010 | 05:41 PM
a_joyner's Avatar
injectors were replaced with stage 2
Old Oct 13, 2010 | 11:28 AM
Sh0nuff's Avatar
Mine is still stock and sounds like this, I also get backfires when shifting from 2nd to 3rd and 4th to 5th.
Car has no codes and all looks good on hptuners.
Car also runs different from day to day, some days like a scalded dog, some days like a fat lazy pig...
Old Oct 13, 2010 | 11:36 AM
when i went 2.8 & 60s it would idle like it had a mild cam
my AEM wideband gauge reads at idle from rich to lean, from rich to lean
when it leans out it reads(- --) its cammed but went the gauge reads(12.0-14.7)
seeing how im not on the throttle its not an accurate read.....all the AEM widebands on lsj's do this
on the throttle (cruising) its at (14.4-15.0) inbetween and at WOT its in the 11's
i think it sounds cool haha at idle plus with the solid mounts
Old Oct 13, 2010 | 07:10 PM
a_joyner's Avatar
Well, I decided to seafoam the engine via the vacuum line. When I fill up tonight, I'll dump the rest of the bottle (2/3's) in the gas tank. It didn't blow out all that much black smoke, but I noticed the tail pipe is all sooty now. It did seem to help the idle some, I can still hear it if I listen by the tailpipe though. Only time will tell.
Old Oct 16, 2010 | 12:40 AM
rukkee's Avatar
My SS/SC did this with 5000 miles on it when i added stage 2 . It had an idle misfire that was very random and would never throw a code .... I had to use a tech 2 to graph it or something simular . My idle would be like errrmmmmmmrmmm puft errrrrrrrrm puft puft errrrrmmmmm puft. My friend was the service manager at the local dealership and we replaced the coil packs , timing chain tensioner , injectors and plugs . I think its just the way the GM tune is.
My car idled just like this .... I know its a redline but same difference
YouTube - 2007 Saturn Ion Redline Exhaust--Dezod 2.75" w/Magnaflow #1
Old Oct 16, 2010 | 01:18 AM
a_joyner's Avatar
That's EXACTLY how my car sounds. My car has always done it though, even before stg 2.Seeing that you replaced all that stuff and it didn't help, I'm not going to waste my money then. . Not sure what can be done about it, if anything. I might try and swap my plugs again...this time to iridium's since those are what's suppose to be installed on it from the factory on 07's. They might have lower resistance or something.
Old Oct 16, 2010 | 11:28 AM
army_greywolf's Avatar
In most cases it's normal to idle like this, what you could do is compare your CKP to CMP on the intake to see what it's doing at idle, it shouldn't have much varience but if it does the next thing is to compare how far out it actually is, and the end result could be timing chain replacement. Otherwise, all is well.
Old Oct 29, 2010 | 07:08 PM
a_joyner's Avatar
How would I do that? I already replaced the tensioner to the new style, and rarely, like once every 100 starts I can hear a rattle in the vicinity of the timing chain, a quick small rev makes it go away. I went ahead and changed my plugs to the OE iridium's. It made absolutely no difference in the idle. Since they are lower resistance than platinum, I thought maybe at idle, when voltage is lowest that it would help. Waste of money...lol. How hard is it to change the timing chain on these cars?
Old Oct 29, 2010 | 07:24 PM
The actual resistance is in the gap and spark load increases with engine load, so at idle, if your having perceived spark issues, but it drives fine, it is not your ignition system.
Your dealer/tech/friend with a good scan tool checks to compare those two values, the book says 2-3 degrees if fine for most cars. What COULD be happening is a dirty injector flowing poorly and causing fuel to pool and thus misfire at idle.
Old Oct 29, 2010 | 08:41 PM
a_joyner's Avatar
I don't think it's the injectors because I just had a stg 2 kit put in it, and it made no difference.....idle is exactly the same as it was with original injectors. Don't know anyone with a scan tool, but maybe I'll take it to the dealer sometime and have them check it out.....how much would a good scan tool like that cost?
Old Oct 29, 2010 | 09:08 PM
crazywhiteboy89's Avatar
mine does it to radomly it have no clue y tho
Old Oct 30, 2010 | 01:15 PM
rukkee's Avatar
If i turned my AC on it would smooth out the idle on my SS/sc .
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
