Running lean..?
Running lean..?
I just got my cobalt back together, and it ran PERFECT even with the canned tune for about 200-400KM then it all went to hell. It is running lean off and on, then rich...then my gauge will pick up a slight misfire etc. My list of mods are in my sig. I got the zzp can tune too. I checked for vac leaks and could not find any...the only spot I can figure is maybe where my meth boost switch is tapped in, which by the way I think is faulty from the factory because I have yet to get my meth working, but that's another topic.
I have also gotten the p1133 code and p0133 code.
Sounds like you have a bad O2 possibly. That would cause all of the issues. Does the car run ok aside from being lean? You could have an exhaust leak before the sensor as well.
I ran the intake for a year before I got the rest of my kit pieced together. Anyways, I replaced the 02 sensor and still nothing. The car when just cruising around will go lean and stay lean for about 1 min then go away and act normal. Or go right to running rich. I would want to say it's my tune..but I ran it for about 300 km or more with the canned tune and it never acted like this.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
