Running too lean?
Old Apr 4, 2009 | 11:33 PM
Ramphex's Avatar
Running too lean?
So my car has been throwing this crap for a little while now... any ideas or suggestions? I erased the code for now since I hate seeing that little yellow icon being on but I'm sure it'll come back soon, it always does.
Old Apr 5, 2009 | 08:34 AM
Coblasts's Avatar
I would go with either there something wrong with your Maf or connections .The p0102
is whats causing the p0107 most likely due to erratic signal due to a bad connection ,
wire grounding out (or a bad ground connection).
The maf still could be bad but with out a spare you would be guessing so I would check
1)maf connector for corrosion clean contact pin with a contact cleaner and make sure there isnt any moisture in the connector if so seal it .
2)wires leading back to pcm and ground for damage
3)ground connecton for tightness or corrosion (wire rotting off of the crimped connector)
Old Apr 5, 2009 | 05:40 PM
jonxxxedge1's Avatar
yeah im having the same problem
Old Apr 6, 2009 | 01:28 AM
Ramphex's Avatar
Let me know what you do if you get it fixed.
Old Apr 6, 2009 | 01:32 AM
JimzSS's Avatar
Have you recently re-oiled your airfilter?
Of course if its a reusable one.
Old Apr 6, 2009 | 09:16 AM
i have a fujita intake, and i read somewhere that the angle they put the sensor causes for a false reading, making that cel come up. but my light only comes on like once a month for a day. do you have a short ram or a cold air?
Old Apr 6, 2009 | 06:52 PM
Ramphex's Avatar
Cold Air.... with a cheap dry filter.
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
DocSvensk
Sep 27, 2015 02:24 PM
