SC bypass
Old Dec 26, 2013 | 09:54 PM
Freddy_Lasers57's Avatar
SC bypass
Im trying to figure out what is sticking. The butterfly in the sc or the bypass valve its self. I removed the bypass and it moves freely. I sprayed some dry lube on the butterfly for the waste gate. it moved freely. took for a test drive and now the darn thing is stuck open again. anyone else have this problem.
Old Dec 26, 2013 | 10:02 PM
ItalianJoe1's Avatar
Probably the bypass actuator, they do fail from time to time.
Have you pulled the blower and cleaned the bore for the bypass valve blade?
Old Dec 26, 2013 | 10:41 PM
No I have not. plan to do so Friday or Saturday. Got to call and get gaskets. The blade or "butterfly" is sticking without the bypass valve even on the car.
Is this something that happens on our cars
Old Dec 27, 2013 | 01:49 AM
Oh I thought you meant the actuator was sticking. There must be some buildup in the blower for it to be sticking, take everything out and clean it up. You can remove that little blade and clean the bore if needed.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
Hugger1975
Oct 15, 2015 03:28 PM
allpro666
Sep 23, 2015 07:47 PM
DevZX
Sep 16, 2015 06:19 PM
