Serpentine belt
Old Jun 27, 2008 | 01:33 PM
sscharged112's Avatar
Serpentine belt
Just one more question lol. I have to replace my belt very soon. I have done them before but the tensioner was always a pulley. This seems to have a tensioning arm. Do i loosen the big bolt under the pully. If so whats the best way to get to the bottom pullys to put the belt around them. How would I be able to put tension on it again...here are some pics
Old Jun 27, 2008 | 01:39 PM
eurochevy's Avatar
theres a spot behind the pully where you can put an wrench open side and just push down it'll compress it and just pull off the belt..not hard
Old Jun 27, 2008 | 01:44 PM
chris88z24's Avatar
Take a 15mm open end wrench and push down on the notch on the other side of the tensioner. It really helps to have a friend help you with this. And when putting the belt on, put the belt on the tensioner FIRST and then the s/c or else you will have one hell of a time getting the thing on. lol
Old Jun 27, 2008 | 01:49 PM
Those are kinda vague..but they help...so your saying I dont have to loosen any bolts or anything???
Old Jun 27, 2008 | 01:51 PM
eurochevy's Avatar
nope..just use the open ended side of the wrench and push down
Old Jun 27, 2008 | 01:57 PM
ok i just tried that the metal piece behind and the the right of the pully...the wrench hit the pully and was starting to crush the side down...so i stopped...it did move though
chris88z24's Avatar
Why the hell did you stop?
Old Jun 27, 2008 | 01:59 PM
eurochevy's Avatar
uhh the wrench shouldn't be hitting the pully man try turning the wrench around so the bend is the other way maybe?
Old Jun 27, 2008 | 02:40 PM
ill just find something else to pry it with...gotta head to work now...is there anyway you can increase the tension to the belt..mine is a lil bit loose
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
