Soft clutch after WOT
Old Jul 10, 2015 | 09:38 AM
alerosaint's Avatar
Just an issue I had that, figured I will post the fix since so much threads talk about the problem and there is no real follow up on the fix.
Problem: At WOT throttle clutch got really stiff and pressure bleed off after shifting leaving the clutch pedal close to the floor barely allowing room for clutch disengage/engagement or stuck to the floor not allowing it to disengage it at all. Pressure always slowly came back eventually to clutch pedal till it felt fine.
Fix: Replaced Master cylinder. It was leaking internally
Old Jul 10, 2015 | 10:58 AM
jcobaltss's Avatar
I had same problem but ended up being tob
Old Jul 11, 2015 | 02:24 AM
tomj77's Avatar
yup mine was tob as well
Old Jul 13, 2015 | 02:51 PM
alerosaint's Avatar
I believe you guys are correct. The master cylinder fix allowed pressure to come back after a couple pumps before it would stay soft for hours. Changing TOB next.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
