Squeak front driver side
Old Mar 22, 2018 | 09:19 PM
Doug's Cobalt SS SC's Avatar
Hey Guys need your help with something. For the first time when driving home from work today & turning left into the gas station I noticed a squeaking sound coming from my front drive side tire area. When backing into my driveway it got worse. I turned my wheel from side to side & it squeaked no matter which way I turned it.
For the record it should be known that about 2-3 years ago I had all of the front end work below done which is why I can't figure out what else it could be ?
Front driver side & front passenger side Hub bearings installed Lower left & lower right control arms replaced Driver side & passenger side struts replaced Driver side & passenger side Sway bar links replaced
Removed & replaced front passenger side & front driver side tie rod end with a brand new Moog outer tie rod end!
Old Mar 22, 2018 | 09:22 PM
In addition guys I just pushed up & down on the front driver side fender & im getting a creaking sound. What the heck could it be ? As you can see I nearly replaced my entire front end cost me over 3k back around July of 2015 to Jan 2016 so the parts aren't that old
Old Mar 22, 2018 | 09:34 PM
Here's a couple pictures of my driver side strut that again isn't even 3 years old yet, it's wet however I just took it through the car wash to get the salt off of her so I'm not sure if this is water or something else
Old Mar 23, 2018 | 06:03 AM
63 Nova SS's Avatar
I would say it's just water. Did you replace the strut bearings when you did the front end? Or sway bar end links? Could also be a sway bar bushing or the steering shaft from column to rack, the little u joint on them goes bad. If it's that you usually have a dead spot in the steering when it's at center.
Old Mar 23, 2018 | 07:08 AM
Yes I replaced both of my sway bar end links about a year & a half ago. I think your correct about the strut bearing, I don't think that was replaced when I had all of that front end work done they just replaced the struts.
If it is the strut bearings that are going out how much are those typically to replace ? & how much longer do u think I can go without damaging anything ?
Old Mar 23, 2018 | 07:25 AM
So nova when I went back and checked it does appear that my front strut mounts were also replaced with my struts however I don't know if they would have also replaced my strut mount bearings when they did my strut mounts or if they would have just re used my OEM strut mount bearings
beatsfanatics
Jul 12, 2010 04:23 AM
kissmySS08
Sep 14, 2009 03:19 PM
NYC_Eddie
Feb 10, 2008 07:29 PM
YellowG5
Jul 5, 2007 02:25 PM
nickabud
Feb 9, 2007 05:38 AM
