squeaking noise
Old Sep 8, 2007 | 05:22 PM
josh22's Avatar
squeaking noise
I was just wondering if anyone has haveing a similar issue, this is my first standard car and it has about 38000 miles every time i press the clutch in and change gears only form 1 to 2nd and 2nd to 3rd i hear a squeaking noise. clutch doenst seem to be slipping at all, so im not really sure what the problem is.
Old Sep 9, 2007 | 11:19 AM
Coblasts's Avatar
Where does the noise sound like its coming from ?
Old Sep 9, 2007 | 11:14 PM
Vetteman-sssc's Avatar
Maybe its the clutch pedal sqeaking?
I know its common for it to make a clicking type noise when you press in the clutch pedal.
The click type noise is the neutral switch i believe.
Good Luck
Old Sep 10, 2007 | 09:41 AM
Misery5567's Avatar
Mine does the same thing and has 9800 miles on it.
It's a quick creak/tink sound and it comes from underneath the car.
Or at least mine does. I spoke to the dealer about it and they were
dis-interested to say the least. I wasn't sure what to make of that.
Problem? Who knows. I figure if it finally breaks something then
they can just warranty it. It's not like they weren't warned/told about
it. They suspect it to be a creaky (not broken) motor/tranny mount.
Old Sep 10, 2007 | 10:46 AM
rnjmur's Avatar
I had the same thing. It is just the clutch pedal squeaking. If you get a little lube you can fix it right up.
Old Sep 10, 2007 | 05:03 PM
josh22's Avatar
thats seems easy enough to fix a little lube.
Old Sep 10, 2007 | 05:06 PM
SmOKe JeNsOn's Avatar
Or take the mouse outta ur pocket.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
