Steering Wheel Light Burnt Out...
These are the ones that I got
20X Blue T3 NEO Wedge SMD LED Light Instrument Cluster Panel Lamps Gauge Bulbs | eBay
They come in different colours. If you want to change the ones in the gauge cluster then you have to do some soldering and same with the HVAC from what I know.
ok thanks for the help.
http://www.ebay.com/itm/20x-Red-T3-Neo-Wedge-LED-Bulb-Cluster-Instrument-Dash-Climate-Base-Lights-Lamps-/291224371912?pt=Motors_Car_Truck_Parts_Accessories&hash=item43ce5342c8&vxp=mtr
So these ones should work? i noticed yours where 8mm base but i dont see it on these ones. Im assuming these shoud work.
And also how to you take the controls off? do you just pop them off or is it more complicated than that?
And do these also work for the door switches or no?
Again thanks for all your help!
20x Red T3 Neo Wedge LED Bulb Cluster Instrument Dash Climate Base Lights Lamps | eBay
For the steering wheel they are a T3 neowedge bulb and they pop in and out without any soldering
Yep, you need raw LED's. 12v LED's are direct replacements. You'll need both 3mm and 5mm LED's for a complete swap. LED's are polarized so be sure you solder + to + and - to -
