Steering Wheel Light Burnt Out...
Old Nov 26, 2010 | 09:05 PM
cobalttuner4698's Avatar
Has anyone ever had an issue where ur Steering wheel lights for the volume controls and so forth have burnt out?..anyway to fix the bulb for this with out having to go get this done at a dealer?...
Any info would be great!
Thanks
Old Nov 26, 2010 | 10:00 PM
Malaclypse's Avatar
The dealership is about the only place to get the part required. I believe the bulb in the steering wheel control is removable... but its so damn tiny I doubt you could even find an LED that small.
If someone has been able to replace their steering wheel control lights with LEDs that'd be awesome news for you, though.
Old Nov 29, 2010 | 09:52 AM
No doubt, I was kinda hoping to skip the dealership...but it looks as if that may be my only option...i'll probably check to see what they charge sometime this week.
Old Feb 18, 2011 | 11:06 AM
tr_8301's Avatar
wonder if there was ever a solution to this? if not, any idea on a dealer cost to fix it?
Old Feb 18, 2011 | 11:53 AM
Fidget's Avatar
Yes you can replace the bulbs in the steering wheel. The bulbs you require are called neowedge I cannot remember the size of the bulb but at least it will put you into the right direction.
Old Feb 18, 2011 | 12:23 PM
ecot3c inside's Avatar
lol I've been wondering if that thing was suppose to be on.
Old Feb 18, 2011 | 12:41 PM
cbro's Avatar
i had the volume light go out on me. Took it to the dealer and they had to order the whole button assembly because they didnt just sell the LED. it only costed 20$.
Old Feb 18, 2011 | 12:43 PM
D_sean257's Avatar
maybe its just a blown fuse.
Old Feb 18, 2011 | 12:45 PM
CTcar's Avatar
My seek button went out, but then one day it came back on, and it's been on ever since. Maybe you will get lucky too lol
Old Mar 30, 2011 | 04:11 AM
Conspiracy2Riot's Avatar
Any more info on this guys? I have the +/- button light out as well as the Band/1-6 button burnt out, and was hoping to do it myself!
Old Apr 17, 2011 | 01:25 AM
megaman311's Avatar
The bulb type is called a Neo Wedge. Use google
Old Apr 17, 2011 | 08:42 AM
C_A_D88's Avatar
depending on year, i know my 07 steering wheel controls use the 0805 surface mount leds
as i have swapped them all out with blue ones
Old Sep 7, 2012 | 11:46 AM
rectorc08's Avatar
What bulb size are they? I have a place that has 3mm, 4mm, and 5mm?
Old Sep 7, 2012 | 03:41 PM
Gelladuga69's Avatar
A couple of my wheel control lights are out as well, lol. Good find.
Old Sep 7, 2012 | 11:24 PM
rokon340's Avatar
Thanks
heres how i fixed mine
https://www.cobaltss.net/forums/appe...-lamps-270939/
Old Sep 8, 2012 | 08:54 AM
rectorc08's Avatar
Originally Posted by rokon340
Great find man. I'm gonna try a 3mm LED bulb and see where that gets me. I'll post results once I get them.
Old Sep 8, 2012 | 01:33 PM
JetBlackSS's Avatar
in for future use....half of mine are out....
Old Sep 8, 2012 | 01:39 PM
Gobolt210's Avatar
my light on my wheel have been out a over a year now
the info button never works when i need it.
Old Sep 8, 2012 | 09:36 PM
06SS ALL DAY's Avatar
Waiting for my steering wheel lights to go out pol. Thank god its only a dub and some change.
Old Sep 8, 2012 | 11:13 PM
rectorc08's Avatar
Bumppp. Anyone know the size? 3, 4 or 5mm?
Old Jan 4, 2015 | 12:01 AM
CobaltCoupeCrazy's Avatar
Hey guys, I haven't been on here in soooo long, but to help with this I can provide the following info: You can get a complete LED replacement for the individual lights in the steering wheel controls. These are Neo Wedge Twist-locks. You can choose from different colors and two different power levels at Super Bright LED's (www.superbrightleds.com). I haven't pulled my switches out yet to confirm what size to order. If anyone knows which size we need, please inform us.
Old Jan 4, 2015 | 12:13 AM
chevygirl2006's Avatar
They are t3 neo wedge
Old Jan 4, 2015 | 12:16 AM
blueLNFftw's Avatar
For all SS or just certain years?
Old Jan 4, 2015 | 12:49 AM
rains_crusader's Avatar
05/06 use incandescent bulbs. Finding replacements is difficult. I bought some from a site a long time ago. They were too bright and got too hot. Most people use 3mm 12v LED's as replacements. Make sure they are 12volt led's or they will burn up. led-switch.com has good prices on these. You'll need to pop the switches out of the wheel. Twist and remove the bulb holders from the back side. Remove the burned bulb, replace with your LED and reinsert it. LEDs are polarized so, if you put it in and it doesn't light up, untwist the bulb holder, rotate it 180 degrees and put it back in. If you want to keep the color of the bulbs close to stock, the closest you can come is the "warm white" LED. Make sure you transfer the blue silicone filter from the old bulb over to the LED. It wont be exact but it should be close.
07+ use SMT LED's 0805's will work just fine but they are smaller than what was used stock. I used 1210's from superbrightbulbs.com
Old Jan 4, 2015 | 12:58 AM
05-06 uses t3. 3mm will not fit. It's way too big.
