Steering Wheel Light Burnt Out...
Old Feb 25, 2015 | 06:36 PM
  #51
CleverOne's Avatar
those LEDs are legit, i used red ones in mine, the 3mm seem to be a little brighter then the 5mm.
Also get the clear and sand paper them a little to diffuse the light.
Old Sep 11, 2018 | 08:28 AM
  #52
71jcguy's Avatar
anyone know where to get the stock dimmable replacement light bulbs for the steering wheel various control buttons?
the led version are too bright and not dimmable.
Old Sep 11, 2018 | 10:58 AM
  #53
chevygirl2006's Avatar
my leds dim on my steering wheel
Old Oct 15, 2018 | 03:16 PM
  #54
71jcguy's Avatar
I guess my do dime, slightly at the bottom range of the dimmer knob, but they are like 15 times brighter then the rest of the dash lights, sarcastically bright, any one know what the part# is for factory like ones or where to get them? led is fine but seems all are too bright.
Old Oct 15, 2018 | 03:53 PM
  #55
Kolt's Avatar
Grab a cheap multipack of resistors ranging from .5k-5k ohm and test run one at a time in series with the leds. Little trial and error but you should be able to find one that matches up with your leds to bring the brightness down and make them more dimmable. Did the same back in high school when upgrading peoples ipc lights.
There isn't a part number for interior lights from gm on the steering wheel, hvac, ipc, switches, ect. I used replacement mini flashlight bulbs from lowes for my hvac in my ls when one burned out. I forget the size though.
seeyaass
Aug 1, 2013 12:50 PM
Driver1
Dec 25, 2011 05:59 PM
miked5426
Feb 18, 2010 06:06 PM
Fidget
Mar 27, 2009 10:11 PM
BlueSS-supercharged
Jun 19, 2007 05:17 PM
