Steering wheel vibration
Old May 20, 2014 | 06:14 PM
i see link above ^
Old May 20, 2014 | 08:30 PM
63 Nova SS's Avatar
Tom is the gm part you stock been improved. Love doing business with you but i don't want to replace it with another one that will do the same thing. I guess dorman redesigned it and took the plastic piece out.
Old May 21, 2014 | 08:37 AM
baileybroSS's Avatar
I don't think it's the intermediate shaft from what I've seen on videos with people having problems with it. I don't have those symptoms. My steering just vibrates after I've been driving awhile. It will be fine then I get on the highway and it's fine I get off and drive in town then it starts to do the wobble. Now today I thought I heard a sound kind of like a bad wheel bearing. So I'm gonna check it out after work. My question is- would a bad wheel bearing cause the wobble? Because it doesn't happen until I've been driving awhile.
Old May 21, 2014 | 08:41 AM
So I don't think it's the shaft after watching videos. I don't have similar symptoms. Mine only starts to wobble after I've been driving for awhile. I thought I heard a sound this morning like a bad wheel bearing. Question is, would a bad wheel bearing cause the wobble?
Old May 21, 2014 | 08:43 AM
Sorry about repeating myself. The first reply didn't show up for awhile until I posted a second time :/ lol
Old May 21, 2014 | 02:13 PM
Old May 25, 2014 | 11:55 PM
Jesse's Avatar
Has anyone found out the solution here? I have a 2.2 car with ~110k and it shimmies like a bitch when accelerating and braking. Practically new(less than 10k) EBC rotors and pads so I know it isn't rotors. Tires are balanced.
Old May 26, 2014 | 04:04 PM
ItalianJoe1's Avatar
Did you check the things mentioned? Control arm bushings and axles are the normal culprits in this problem, could also be the steering shaft that CED posted a link to but that's less common than the other failures.
Old May 26, 2014 | 04:56 PM
CrateEngineDepot's Avatar
The part number has changed twice in the last few years but I have no way of knowing of any changed made
Old May 26, 2014 | 06:08 PM
COBALTace's Avatar
MAbey try filling your tires a little more?....other than that could be the shitty electric power steering love from GM
Old May 27, 2014 | 05:41 PM
  #36
I think I figured it out. I have a piston in my Brembo caliper that is sticky it doesn't always want to release. I checked everything else so I double checked the brakes. I just order the Brembo rebuild kit from CED. My brother in law who is a gm certified tech helped confirm this. Were both positive that it's the cause
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
Tupp
Sep 30, 2015 08:18 PM
