Strange Boost Issue
Strange Boost Issue
Hey all, I made a post similar to this a few months ago, and seem to be having the same problem again. I would, most of the time, get full boost, 12-14 psi depending on weather conditions.
A few months ago, it would not get past maybe 9 or so psi, making a strange whooshing sound, almost like the turbo was just much louder. Now again, after ordering a ZZP PCM, the problem is back. It is fine with the stock ecu, but with theirs, i can never boost past 10 psi or so, depending on the gear i'm currently in. I talked with ZZP via email many times, and they were very helpful, even sending me a new ecu to see if it was the ecu causing the issue. The problem is obviously on my end.
-There is no CEL at all, no boost leaks at all, I checked the bpv for tears, and anything else I could fine on here or any other site. Any insight would be appreciate as im just running out of ideas and things to check now.
I went over both Intercooler pipes well, checked the entire intercooler for cracks.
The car has 73k miles, only other mods are mpx catback and AEM intake right now. I haven't done a proper boost leak test in many months though, just an inspection of everything quite well.
