Stupid Electrical Problem - No Crank/No Start
Old Nov 1, 2014 | 11:25 PM
SSteveSC's Avatar
Hey all, I've searched and searched and cannot find a solution to my problem......
When key is in the run/crank/off position, all accessories inside the car turn on.. PCM gets voltage, fuel pump gets voltage, etc.
When I go to crank the car over, I hear the relay in the BCM click, but that is it.. Nothing happens from there.. I think I have it narrowed down to a dark green wire from connector 47 on the Grey PCM connector, and a yellow wire coming from the clutch pedal switch.
On a side note, I can jumper the crank relay and the starter will turn the motor over and start the car. So its something to do either with the clutch pedal switch or PCM.. My problem with the clutch pedal position switch is that I cannot get to the damn thing! Where does that wire come into the engine bay????????
Solaris99
28
Mar 15, 2017 01:22 PM
brandon04
Oct 21, 2015 07:04 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
