Supercharger knocking
Old Jan 31, 2009 | 01:15 AM
xxFISHxx's Avatar
My S/C knocks! It is not a constant thing but this is when it usually happens:
I drive the car around enough for the engine to be plenty warm enough, I shut it off for about 20 minutes or so, and about 5 minutes after I start the car back up, once the engine gets warmed up again, the S/C starts knocking.. It will knock for about 5 minutes or so, and then stop. It sounds like bad bearings to me, i know thats more than likely not it since its not constant, but that is about the only thing i can compare the sound to. And I when you put your hand on the S/C you can feal it knocking, so I know that is where it is coming from. Any ideas/others with this problem?
Car is completly stock....
Old Jan 31, 2009 | 03:31 AM
fzn14's Avatar
SC balancer is going bad.....Sound like rocks inside?
Old Jan 31, 2009 | 03:33 AM
Darkmanx's Avatar
lucky for your the average price of a m62 supercharger is around 250 to 300 bucks.
Old Jan 31, 2009 | 02:23 PM
xxFISHxx's Avatar
That is exactly what it sounds like! Thanks! i would assume that would be covered under warranty???
Old Jan 31, 2009 | 02:25 PM
fzn14's Avatar
If you if you have no mods then yes...If not i know there is site that sells them, I would go to the dealr 1st and see that they say and go from that, I wouldnt see why it is not coverd
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
z28addiction
Sep 28, 2015 12:03 AM
