Supercharger Rattle/Rasp - Will this fix it?
Hi guys,
I'm looking at a M62 rebuild kit, it's pretty cheap and I want to try it first before buying a new M62 for a grand or so.
This is the kit:
M62 Upgraded Rebuild Kit (Coupler/Bearings Upgraded)
Basically, I just want to know how difficult it would be to install these myself (AND if this would most likely fix the issue)? I know the coupler is easy, it's the bearings I'm more worried about. If the bearings are a pain in the *ss, do you think a professional could do it for say under $300?
Thanks for any suggestions!
This is the kit:
oh nevermind, not for 60 bucks i thought you meant 300 lmao. yea that stuff should set you on the right track, be sure to check out your blower rotors. is the black teflon coating in good shape? if you take them out, how does your rotor housing look? all scratched up? if thats all good then yeah the other stuff should put you on point.
when you put in new oil --- 3.4 OZ!
Thanks again!
Its a pain in the ars...It might fix the issue but not worth the time and effort unless you have the proper tools to do and have the know how, also you might have issues with the rotors.... I personally done and would not do it again lol...Like Mr. Rice said its better to buy a used one or try replacing the coupler first and re-grease the needle bearings and see if that helps.
correct on the oil fill amount. never add 2 bottles like zzp recommends.
Fixed
Turns out it wasn't the sc, but a broken flex pipe and messed up cat. Dealership replaced both for free, there's a warranty on these until 2016.
Thanks for hearing me out and helping!
All Eaton superchargers (including aftermarket partner companies like Magnuson) use the same supercharger oil. It is called NYE 605 and can be purchased from any GM or Ford service parts distributor or dealership (usually known only as supercharger oil). The gasket between the 2 surfaces that will be broken when you disassemble it will also need to be replaced. You can use LocTite 510 (pink) liquid gasket for these 2 gaskets. Sometimes when you break the front cover seal, the seal between the next 2 surfaces stays intact and does not need replacement. That 2nd seal is only for air only so its less important.
You will have to remove the snout, drain the oil, replace the coupler, clean the seal surfaces with alcohol or some other solvent, let the surfaces dry, apply sealant around perimeter (make sure you go all around each bolt hole for a complete seal, and reassemble. Tighten and torque in a star type pattern. Re-fill with ~200ml (6.7oz) of oil. This should be the amount that comes up to the threads on the oil hole when the supercharger is on a flat table.
Torque on front cover (snout) bolts = 24-30 N-m (18-22 lb ft)
Torque on oil plug = 7-14 N-m (5-10 lb ft)
two bottles would be 8oz, the correct amount is 6oz per eaton and zzp, 3.4oz would be barely enough to even reach the bottom of the gears.
On a level surface the oil level should be just below the fill port. These are the instructions eaton emailed me several years ago for the M45/62.
All Eaton superchargers (including aftermarket partner companies like Magnuson) use the same supercharger oil. It is called NYE 605 and can be purchased from any GM or Ford service parts distributor or dealership (usually known only as supercharger oil). The gasket between the 2 surfaces that will be broken when you disassemble it will also need to be replaced. You can use LocTite 510 (pink) liquid gasket for these 2 gaskets. Sometimes when you break the front cover seal, the seal between the next 2 surfaces stays intact and does not need replacement. That 2nd seal is only for air only so it’s less important.
It's 3.4oz. I also spoke to an Eaton engineer about it. I pitty the people who listened to ZZP about the oil fill level. They are, and always have been incorrect. Sorry.
https://www.cobaltss.net/forums/2-0l...94/index3.html
Below is the link that used to be on Eaton's website:
http://www.superchargersonline.com/i...age=page&id=58
6oz lol no.
It's 3.4oz. Go on Eaton's site. It has the exact fill amounts for each of its blowers. I also spoke to an Eaton engineer about it as well. I pitty the people who listened to ZZP about the oil fill level.
I saved that link from back in the day when they had it on their site.
Did you read both links i provided??
The first is a thread on here about the correct fill amount, and the other is the link that used to be from Eatons site on oil fill amounts.
They no longer have it on the website, nor do they have any info about the M series blowers. I just checked.
OEM Application Rotor Type Oil Fill (fl oz)
Audi A6/S4 TVS / R1320 5.2
BMW / Mini 3-lobe / M45 4.9 + 1.4 (rear)
Mercedes M271 3-lobe / M45 4.6
Mercedes EVO M111 3-lobe / M45 3.7
Mercedes Clutched 3-lobe / M62 3.7
Ford 3-lobe / M24 1.2
Ford Super Coupe 3-lobe / M90 8.1
Ford Shelby GT500 3-lobe Hybrid / M122 4.7
Ford Harley-Davidson F150 3-lobe / M112 7.3
Ford Lightning 3-lobe / M112 7.3
Ford Cobra 3-lobe / M112 7.3
GM 3800 Series L67 3-lobe / M90 7.6
GM 3800 Series L32 3-lobe / M90 6.9
GM Cobalt SS LSJ 3-lobe / M62 3.4
GM Cadillac LS3 Northstar 3-lobe / M112 7.3
GM Cadillac LSA TVS / R1900 5.1
GM Corvette LS9 TVS / R2300 5.1
Jaguar AJ33 3-lobe / M112 7.3
Jaguar AJ43/44 3-lobe / M112 7.3
Jaguar AJ133 TVS / R1900 5.1
Nissan 3-lobe / M62 3.9
Volkswagen 3-lobe / M24 1.4
I did, im going to contact eaton and re-verify the information again, because I find 3.4oz to be extremely low given the difference in size of the snout compared to the smaller snouts that require 6.4oz. 3.4oz wouldnt even be enough to properly lubricate the exposed bearing on the snout side let alone the oil being pulled up through the gears churning at 15,000rpm.
What I have posted is correct and was from eatons website. There is nothing to debate, but feel free to contact them.
Let me put it this way.... I completely drained my H62 and it had right around 3.4 oz or 100ml of fluid in the snout, and thats what I put back in.
It's been over 2 years since I did that, and many high rpm runs and no issues at all with my blower.
I posted that for anyone who cant view the link.
Kinda like how I cant see the pics you post. Got it?
Brent Bussell
Customer Support
Technical Specialist
BrentABussell@Eaton.com
Phone# (800) 328-3850
Direct# (248)226-6762
Fax# (248)226-6740
Kinda pissed off that I dumped an entire 6oz bottle in this thing per eaton's first recommendations and ZZP's refill instructions. Guess ill be getting a syringe to draw some of this **** out. I have a friend looking for the alldata instructions for GM's service procedure as well, im curious if that matches up with what eaton is saying. Don't know why ZZP would have people intentionally overfilling these things.
I find it very unusual because they are a direct supplier of eaton parts, I dont see why that information wouldnt be readily available to them. Unless there is something different in a GM service manual, but I dont have one on hand to reference, thats why im trying to see if I can get the information through a friend at a dealer.
