supercharger rattling at idle
Old Mar 3, 2008 | 03:33 PM
xxFISHxx's Avatar
after my car is warmed up, at idle there is a loud rattling noise that is heard from inside the car. At first it sounded like a loose exhaust to me. I opened the hood and it is coming from the supercharger housing. it sounds to me like bad bearings. it only does it at idle though. you give it alittle bit of gas and it goes away from what i can tell. and also in second gear it seems to bog out up to about 2800-3000 rpm or until boost kicks in then it runs like it should. I was wondering if anyone else has had these problems? and if something is wrong, is it covered under waranty?
Old Mar 3, 2008 | 03:36 PM
Brian MP5T's Avatar
Search function...
It's quite common...
Dealer... Fix...
Old Mar 3, 2008 | 03:37 PM
Steven Flit's Avatar
does it only do it when it's cold at idle? If so thats normal for our belts to make that noise. It goes away once your coolant temps reach roughly 95+ degrees.
Old Mar 3, 2008 | 03:40 PM
06BrandonSS's Avatar
Do you have a different pulley on? If so check your bolts, they may be loose. My friend didnt get his tightened up all the way and it rattled.
Old Mar 3, 2008 | 03:43 PM
xxFISHxx's Avatar
no it does it well after the car is warmed up. and its not coming from the belts, it coming from inside the blower housing.
no it's all stock.
Originally Posted by Brian MP5T
Search function...
Dealer... Fix...
do you have a link? i would like to know whats wrong with it. and what about 2nd gear bogging out?
Old Mar 3, 2008 | 03:45 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Just go to the dealership... warranty is your friend.
Second gear bogs out below that because you aren't making enough horsepower to spin the blower and go fast yet.
Old Mar 3, 2008 | 03:48 PM
07cobaltss's Avatar
sounds like timing chain tensioner syndrome... dealer fixie.
Old Mar 3, 2008 | 03:50 PM
xxFISHxx's Avatar
something is fu*&ed up it shouldn't be bogging as bad as it is
Old Mar 3, 2008 | 03:51 PM
GO TO THE DEALERSHIP... right now! You still have a warranty?
Old Mar 3, 2008 | 03:55 PM
07cobaltss's Avatar
i hope so... might be a combo of clogged cat, and timing chain tensioner... honestly man we are giving you shots in the dark because we can not see, nor look at it. your better off asking my 3 year old niece. go to the dealer and have them check it out.
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
