Surging while acceleration
Old 09-09-2018, 11:34 AM
Joe07supercharged's Avatar
I am getting some surging while I am medium accelerating especially in the beginning of second gear. ?????
Old 09-10-2018, 10:28 AM
ProfDNS's Avatar
Nobody is going to help you unless you provide specifics. Forum 101 man.
For example:
1) Year / Model
2) Mods
3) CEL Codes noticed
4) Driving style
These are need to know.
Old 09-12-2018, 12:20 AM
07 ss/sc
k&n cold intake
B.s.pieced together exhaust (it's the way it was when I got it)
never had any issues til now
Old 09-12-2018, 07:39 AM
jdbaugh1's Avatar
You have no check engine light? And by surging to you mean it is cutting out then taking off? Does it feel like it is misfiring?
Old 09-12-2018, 11:37 PM
Under medium throttle it pulls harder and lighter. Mash on it and it just pulls hard. ( accelerates evenly ). No there are no idiot lights on. No codes
Old 09-12-2018, 11:38 PM
Not missing either
Old 03-24-2019, 06:51 PM
whygoslo's Avatar
I had a similar issue, throttle would surge sometimes at idle, sometimes when cruising. Only happened when engine was warm.
A bad temp sensor was the culprit. When engine is hot, system is closed loop and uses the coolant sensor output when calculating air/fuel mixture.
When viewed on a scanner, you could see the temp sensor drop to 0 degrees or lower. As soon as the temp sensor started to drop, the throttle would surge. The more the temp dropped, the higher the RPM surge,
Replaced the coolant sensor, everything is perfect.
hoplite
09-23-2017 11:32 AM
seoulgirl7
11-04-2010 11:04 PM
killianss
09-19-2010 02:24 AM
SSturb
09-11-2008 01:22 PM
ikeryder13
06-24-2007 04:03 PM
Quick Reply: Surging while acceleration
