Swapping superchargers
Old Jun 28, 2011 | 12:07 PM
Shogokuma's Avatar
Hello all, this is my problem.
my superchargers release valve is all rusted and got stuck at one point, but i managed to used ruscheck lube and un seized it. now i feel its going to get seized again at some point.
SOLUTION: swap with my friends supercharger that the bank is repossessing. now this car is in bad shape but no rust. its got a check engine light and the rev bounces up and down.
question: will my car run like crap or the supercharger itself is purely mechanical.
what would you do cobaltss.net?
Old Jun 28, 2011 | 12:09 PM
Chevycobaltss3's Avatar
Id swap the SC OUT alonng with all the good parts. ecs if the car has less miles!!!!
And wasnt beat on all the time!`
Last edited by Chevycobaltss3; Jun 28, 2011 at 12:09 PM. Reason: Automerged Doublepost
Old Jun 28, 2011 | 12:15 PM
Shogokuma's Avatar
i have read about it there are 4 torques and the tentioner you can just pull down with a torq also right?
Old Jun 28, 2011 | 12:27 PM
Shogokuma's Avatar
there also a LSD in that car but i dont have the tools to swap that..
Old Jun 28, 2011 | 12:29 PM
The supercharger has 4 hex wrench bolts. The tensiner pulley u need a 15mm to remove the belt. If theres a pulley swap you will need to tune and injectors and ect tho so watch out if so!
Old Jun 28, 2011 | 12:31 PM
keiserX13's Avatar
Swap everything that is in better condition on his car!
Old Jun 28, 2011 | 12:35 PM
nizzle's Avatar
the actual valve on the SC or the BPV that attaches to the SC? Because you can get a new BPV (bypass valve) from ZZP for $45.
Old Jun 28, 2011 | 01:13 PM
Shogokuma's Avatar
ni its what the bpv opens like the butterfly, i called eaton and its a part that isnt sold
Old Jun 29, 2011 | 07:59 AM
Shogokuma's Avatar
hahah nevermind OMG the supercharger was full of mud... i cleaned it and put it back together and left my car intact
Old Jun 29, 2011 | 08:03 AM
cmatthewb101's Avatar
YouR SC got filled with mud? Need driver mod...
Old Jun 29, 2011 | 08:19 AM
keiserX13's Avatar
how do you get mud in a SC?
Isn't that the point of an Air Filter?
Old Jul 2, 2011 | 08:56 PM
Shogokuma's Avatar
Not my supercharger mine is ok
Old Jul 3, 2011 | 12:27 AM
kstorm61's Avatar
its pretty ease to swap them.. i did that with a buddy of mine. he already had a zzp hub pressed on his. So when i droped my pulley just traded my sc for his
brandon04
Oct 21, 2015 07:04 AM
ThoR294
Oct 4, 2015 08:44 PM
ThoR294
Sep 28, 2015 05:31 PM
z28addiction
Sep 28, 2015 12:03 AM
