tac's acting funny
Old Apr 9, 2006 | 05:57 PM
psychocobalt's Avatar
tac's acting funny
I noticed a while back when I turned off my car the tacs jumped lil speratically. Then today they same thing they rose, drop, rose, drop. Anyone else had this problem? This is on the 06 LS 2.2 automatic.
Have alost noticed it seem to idel funny at stop lights, almost like it wanted to stall!!!???
Old Apr 9, 2006 | 10:39 PM
HackAbuse's Avatar
when i push the revs to about 3k, then let off the gas really fast, sometimes the engine jumps 400 more rpms before starting to drop
Old Apr 9, 2006 | 10:42 PM
x8xViperx6x's Avatar
Yeah, just last night, when I hold the clutch-in ( I have 5-speed ) to start my car, the rpm revs up in down, to about 1100 down to 800 and back up again, just for a few seconds, then levels at just under 1k.. its wierd..
Old Apr 9, 2006 | 10:45 PM
CobaltCowboy's Avatar
i haven't watched the tach but i have heard the engine revs similar to what you guys discribe. i would assume it's normal.
Old Apr 9, 2006 | 10:46 PM
I hope so. Cause if it isnt........... thats gunna suck.
Old Apr 10, 2006 | 02:48 PM
05sedan's Avatar
my car does this every once in a while as well...seems to be normal
Old Apr 10, 2006 | 02:52 PM
distillion's Avatar
that happened to me too, jsut chillin in my car with it off and i noticed the tac and speedo bouncin a bit??? wierd.
Old Apr 12, 2006 | 10:11 PM
Blown 4-banger's Avatar
when im in neutral and i rev the engine above 3000 it comes back to about 1500 and sits for about 1 second then drops back to like 7 or 800
Old May 21, 2006 | 11:35 PM
Smiles's Avatar
mine does that when I take the key out and wait a minute. just before the time turns off on the radeo, the gages shimmer a little. not sure why
Old May 21, 2006 | 11:58 PM
REIGN SS's Avatar
Original Hayden Fanatic
i notice it jumpin around if i start it in gear(5-speed, duh), but not so much if im in neutral.
Old May 22, 2006 | 12:42 AM
tiny's Avatar
its because of the throttle by wire system, the tac is a little delayed. you will also notice that you actually hit redline before the tac says so
thats normal for when a car starts up, dont worry
Old May 22, 2006 | 12:23 PM
jokieman's Avatar
Yes. I've had this problem on our 2.2LS auto as well. With the car off, if you're fiddling with the cd player, like, say, changing cd's or something, it will jump around a little bit. I had it happen once in my in-law's Impala SS too, but i'm still not comfortable with it.
Old May 22, 2006 | 12:35 PM
snobird's Avatar
everyime when i shut her down it jumps for about 30 45 secinds then it stops my friends dose the same no problem at all just a little bug or something jsut tell people you ruun at 30 psi and it is trying to wind down ahhaahah
turbochargedss2012
Sep 20, 2023 12:17 PM
The Rookie24
Jan 20, 2016 05:14 PM
vjoel2011
Oct 2, 2015 12:11 PM
roth
Sep 26, 2015 12:16 PM
jeremiahjack95
Aug 24, 2015 04:21 PM
