temp concern
Old Jan 6, 2011 | 09:19 AM
Tha Cavi Kid's Avatar
temp concern
I have a 06 ls 5spd with 73,xxx miles one it.. I notice them coolent temp likes to move a little more then it used to. When I first started watching the engine temp, it would idle and Cruz at 185-187. For the past week the car would get up to 190-192 driving with heat on. And if i sit at a light to long it will get up to 196 or 198. Not going past that... again, with heat on. This morning I decided to try something... so I turned my heat off on the drive to work.. and the car was cruising at 183 and at a long stop light got back up to 187... but not past that. I don't understand it, and am wondering what you guys think? Should I be worried, or is it nothing? The car isn't losing coolent and the block isn't sweating under the head, so I don't think its the head gasket. I also checked the oil yesterday after doing my oil change... no coolent in the oil. The heat in the car is strong like always has been since I got it. Ideas?
Thanks in advance.
Old Jan 6, 2011 | 11:17 AM
kidcrash603's Avatar
is this your first winter with the car?
I'm taking a total stab in the dark that maybe the car is programmed to run a few degrees hotter in the winter to keep your heat temp up?
Regardless, those temps aren't hurting anything.
Old Jan 6, 2011 | 11:30 AM
Kyle4236's Avatar
your fine my old balt would run up to 210 in the winter
Old Jan 6, 2011 | 12:05 PM
Yep first winter with the car. The cav I had before had an analog temp gauge, so i never saw changes that much. Now all I watch is this digital one.
Thanks guys for the heads up. Glad it is nothing to worry about.
Old Jan 6, 2011 | 12:07 PM
ecot3c inside's Avatar
mine gets up to 190 at the most right now and it's cold. It's a shot in the dark, but those temperatures sound fine. possibly the engine works harder when you put on the heat because the alternator has a little more stress to keep the a/c blower on for your heat?
Old Jan 6, 2011 | 08:31 PM
Malaclypse's Avatar
Start worrying if you climb past 225 degrees and it doesn't start to cool down.
Old Jan 6, 2011 | 09:24 PM
insylem's Avatar
Thanks in advance.
Sounds normal to me...
I have the SS/ LSJ Engine, 06 5spd and if I sit arround idleing my temp has gotten over 200.
180 is normal, 190 is still normal.
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
hhrfreek
Sep 11, 2015 01:28 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
