Thermostat done?
Thermostat done?
The car usually sits around 180-190 coolant temp on an 80 degree day. Recently it refuses to go above 160. So Im thinking the T-stat is stuck open.
If so, how hard is it to replace? Am I going to have to pull my damn header again? I havent gotten back there to look at it yet...
Sure sounds like a stuck t-stat to me.
Can't really help you on the replacement but it looks pretty tight in there - hope you got small hands
This thread might help - good luck
It's not bad at all. If I remember correctly, it's just three bolts and the cap comes off. I did it in 20* weather, so I really didn't take my time. I left the coolant lines attached and was still able to lift it up enough for remove and replace...
I just changed my T-stat last month. I was getting a coolant leak. Turns out the t-stat gasket tore. I loosened the drain bolt on the water pump to let the coolant in the upper part of the engine drain. When you unbolt the 3-bolts on the T-stat housing some more coolant will come out, but nothing crazy. Drop the new t-stat back in, bolt it up, and add/bleed the new coolant. Not a hard job, just a pita of an area to work. I suggest having a buddy around to hold the T-stat housing up while you remove / replace it.
Fyi there is no need to remove any coolant lines.
Looks like its just a lil tight back there but that shouldnt be a problem. My main concern was having to remove the header, which would not only be a giant PITA, but also mean replacing the manifold studs since I barely got away with reusing them the last time i swapped header. They are done.
Mine went out last month also. Took me a couple hours because I had a hard time getting to one of the bolts because the dam hose clamps were in the way. I removed the fuse box so I had enough room to adjust the location of the hose clamps, then the third bolt was a charm to get out.
fivepointohman
Jun 15, 2007 05:01 PM
