Thermostat P0128 Code
Old Nov 13, 2012 | 01:20 AM
tonio5555's Avatar
CEL went on the other day. It came up as a P0128 Code (basically bad thermostat from what I read). I cleared the code and it hasn't come back since. I've been monitoring the coolant temperature on my DIC and it's reading normal. Should I bother changing the thermostat if the P0128 code doesn't come back? Car has a little over 90k on it.
Old Nov 13, 2012 | 01:23 AM
BankerBalt's Avatar
have you replaced the thermostat before? i'm a preventative maintenance guy so i would say change it cuz it's cheap and easy fix but as long as your temps are staying solid where they're supposed to, it might've been a single bad read that caused the code
Old Nov 13, 2012 | 10:34 AM
tonio5555's Avatar
No. Other than oil/filter changes the only maintenance I've had to do so far is replace the fuel pump.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
