They told me I overfilled my oil...
Old Apr 5, 2010 | 06:00 PM
zerbit13's Avatar
I had my 08 ss/tc in the dealership over the weekend to look for a suspension noise and while it was in there, i had them check out the oil leak i have. They told me i over filled my oil when i changed it.. Now i know i did not over fill it.. so what are some possibilties for the oil to leak out of the dipstick tube??? Thanks
Old Apr 5, 2010 | 06:36 PM
Coblasts's Avatar
That might be a leaking intake gasket which was popular with the SC but not sure with the TC if this is possible.
When the intake gasket leaked:
Boost pressure would leak into the crankcase and blow the dip stick and oil out of the tube.
Old Apr 6, 2010 | 12:22 PM
insylem's Avatar
What about a bad Positive Crankcase Ventelation Valve? Do we have them?
Your crank case breether tube could be cloggled as well. It goes from behind the engine
on the passangerside, to the intake.
Old Apr 6, 2010 | 12:42 PM
Illini_06SS's Avatar
So did you actually overfill the oil? Because if you had, the dipstick would show that it's overfull. It's a pretty easy thing to check and not subjective at all (and you should check it on a regular basis to ensure you don't have a gasket leak or burning oil).
Old Apr 6, 2010 | 04:44 PM
Permafried-'s Avatar
How much oil did you put in? On the SS/TC I suggest going by the manual and NOT what the dipstick reads, it's inconsistent from car to car in my experience.
Old Apr 9, 2010 | 12:41 AM
zerbit13's Avatar
I put 5 quarts in what the book says and the dealer.. there is no way it was overfilled. I rotated my tires as the oil was draining out. I had some a/c work done when i bought the car cuz it wasnt working after that the pcv was broken off for a bit until i noticed it was off. but that was well b4 i had noticed the oil leak. It has uv dye in it. I need to put it on a lift and investigate.
Old Apr 9, 2010 | 12:44 AM
Berto09ss's Avatar
i thought it was 6qt's
Old Apr 9, 2010 | 01:06 AM
zerbit13's Avatar
dont quote me but i believe the 05-07 were 6 qts, from all the resources i have seen said the 08 takes 5.
Old Apr 9, 2010 | 09:55 AM
northvibe's Avatar
ya lsj = 6qt
lnf = 5qt
dont f that up :P
You can over fill if you put 5 in as not all the old oil drains out. do you check the level of the oil after an oil change on a flat surface?
Old Apr 9, 2010 | 08:18 PM
SPLREDLINE's Avatar
My 2004 Redline with a lsj has been taking 7 full quarts since the first oil change 149,523 miles ago. just getting ready to do the 50th oil chage on her within the next week or two.
Old Apr 9, 2010 | 08:28 PM
Cobalt_Daddy's Avatar
This is why I pay the extra money and let the dealership do everything .. then they can't accuse me of anything and **** me out of the warranty I paid for.. A.K.A the price of a new car. When my warranty is done then I will tinker
Old Apr 10, 2010 | 12:18 AM
zerbit13's Avatar
Originally Posted by northvibe
ya lsj = 6qt
lnf = 5qt
dont f that up :P
yes i do. Like i said b4 i let all the oil drain out. i fill 4 qts. let the car down start it up and add the fifth till its full. My question was what other than the PCV could cause oil to be pushed out of the bottom of the dipstick tube.
Old Apr 10, 2010 | 12:43 AM
northvibe's Avatar
where the dip stick tube enters the engine or at the top of the dip stick? pressure from the engine can push the dip stick out.
Old Apr 10, 2010 | 01:01 AM
zerbit13's Avatar
from my understanding of the service writers description its coming from where the dip stick tube meets the block. Im hoping to break out the black light tom and check it out.
dennis69
Oct 20, 2015 04:49 PM
satisfied
Oct 19, 2015 12:35 AM
agentirons
Oct 16, 2015 02:11 AM
Trav3480
Oct 1, 2015 08:17 PM
irvin316
Sep 25, 2015 12:41 AM
