Throwin Some Codes... Help?
So I finally checked the codes I've been throwing since I put on the header/dp and here they are...
P0141 - Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0036 - HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0054 - HO2S Heater Resistance (Bank 1, Sensor 2)
Anyone know how to fix 'em? I cleared them out so we'll see if/when they come back.
Thanks
Thanks
how about you plug in the sensor, if it is, inspect the wiring for damage, if none found, replace o2 sensor.
yup, that ***** totalled, yo!
Last edited by GutterPalAl; Dec 10, 2008 at 04:04 PM. Reason: Automerged Doublepost
^^Probably totally failed by now. It's been like that since May so it's not really hurtng the car any. But then again my clogged or blown cat right now isn't helping......
