Throwin Some Codes... Help?
Old Sep 21, 2008 | 01:11 PM
Billig ss/sc's Avatar
So I finally checked the codes I've been throwing since I put on the header/dp and here they are...
P0141 - Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0036 - HO2S Heater Control Circuit Sensor 2 ECM, PCM
P0054 - HO2S Heater Resistance (Bank 1, Sensor 2)
Anyone know how to fix 'em? I cleared them out so we'll see if/when they come back.
Thanks
Old Sep 21, 2008 | 01:16 PM
nuttzzy's Avatar
they will i got the same...your DP dose iy have a HF cat or just a stright pipe.
Old Sep 21, 2008 | 01:48 PM
Yea I figured as much. I've got the high-flow Vibrant d/p
Old Sep 21, 2008 | 01:55 PM
ikeryder13's Avatar
mine as well... any way to stop them?
Old Sep 21, 2008 | 01:56 PM
I dunno, that's what I'm trying to find out. I cleared them off but I'm sure they'll be back.
Old Dec 9, 2008 | 08:47 PM
bbbevans89's Avatar
ever solve the problem ive got the same codes i got an xtc with a vibrant cat
Old Dec 9, 2008 | 10:46 PM
Nah I just kinda left 'em. Wasn't really hurting the car any so I just got used to seeing a CEL haha
Old Dec 10, 2008 | 12:07 AM
Dainslaif's Avatar
Replace the rear O2. That's not a cat inefficiency code, something jacked up the wiring and it's just not working.
Old Dec 10, 2008 | 04:03 PM
bbbevans89's Avatar
its the bosch 02 sensor that throw the p0141
Old Dec 10, 2008 | 04:04 PM
JRelly's Avatar
That combination of codes means you blew your motor. Sorry.
GutterPalAl's Avatar
how about you plug in the sensor, if it is, inspect the wiring for damage, if none found, replace o2 sensor.
yup, that ***** totalled, yo!
Last edited by GutterPalAl; Dec 10, 2008 at 04:04 PM. Reason: Automerged Doublepost
Old Dec 10, 2008 | 04:07 PM
Halfcent's Avatar
I'm old school
That combination would indicate that the O2 sensor is either not hooked up, or it has failed completely.
Old Dec 10, 2008 | 04:46 PM
^^Probably totally failed by now. It's been like that since May so it's not really hurtng the car any. But then again my clogged or blown cat right now isn't helping......
CudaJoe
May 22, 2013 09:05 PM
sic_infested
Aug 27, 2009 12:08 AM
kqst786
Apr 14, 2009 03:11 PM
Area47
Nov 2, 2007 11:22 AM
shortyhend2004
Sep 4, 2006 01:39 AM
