timing issue
Old Jan 29, 2014 | 03:36 PM
josh6854's Avatar
timing issue
Before installation, if the exhaust is set at 10 with red link and intake at 2 with blue link would I need to move anything else? I heard something about 12 position before.
Old Jan 29, 2014 | 07:29 PM
Balt_2.2's Avatar
There should be 3 timing marks on the chain. 10 o'clock for the exhaust sprocket, 2 o'clock for the intake sprocket, and 5 o'clock for crankshaft sprocket. All 3 marks on the chain should line up with those in there positions.
Old Jan 29, 2014 | 08:14 PM
JapEatr's Avatar
South Central *********
Yup and you will likely have to rotate the wxhaust cam into position once crank is at TDC and intake at 2
Old Jan 29, 2014 | 08:52 PM
ItalianJoe1's Avatar
Yeah the valve springs will hold it sort of close but off a bit, I usually get the gears on the chain in position and rotate the cam until the gear pops on, put a bolt in it and you should be good.
Old Jan 29, 2014 | 10:56 PM
josh6854's Avatar
But is it possible for both top gears to be lined up and the bottom not be?
Old Jan 29, 2014 | 11:36 PM
Yeah if it's out of time... gotta turn the crank until it lines up.
Old Jan 30, 2014 | 07:27 AM
Staged07SS's Avatar
Administrator
Administrator
I explained what to do in your other thread....
Old Jan 30, 2014 | 08:16 AM
JapEatr's Avatar
This
Old Jan 30, 2014 | 01:48 PM
jp1600's Avatar
good god you have been at this for days, listen to mr b, take it to a shop. This is a 30 min job max.
Old Jan 30, 2014 | 07:28 PM
josh6854's Avatar
Guys.... I know my stuff everyone ive contacted has said different things. Ive been told to remove the timing cover and some say not to I'm replacing anything just timing it. No new chain
Old Jan 31, 2014 | 07:12 AM
Staged07SS's Avatar
Administrator
Administrator
If you followed what me and mrb told you to do, you would have this done.
Old Jan 31, 2014 | 10:46 AM
If you are still that confused, pull the front cover and verify that the bottom mark is on. It takes all of 5 minutes to pull the front cover at this point and you can be 100% sure that you are doing it right.
Turbo Johnny
Feb 21, 2019 09:41 AM
Barkleyj605
Oct 24, 2015 12:07 AM
The Rookie24
Sep 20, 2015 04:33 PM
OrangeK
Sep 20, 2015 03:02 AM
TrevorB
Sep 14, 2015 03:59 PM
