Traction Off and ABS indicators still on.
Lurking here awhile and am impressed with know how on this site. Hoping you can shed some light on a problem I am having with my 2007 Cobalt SS. Recently had the SERVICE TRACTION warning with the ABS light on at the same time, this happened about 8 weeks after dealer installed break job. I have checked with a OBD2 code reader but it shows no stored codes. Even after many starts light still on. Also disconnected battery to try and reset, no luck. Only thing not checked are the ABS sensor connections for moisture etc. Any other ideas? Thank You
yea i knwo standard obd2 readers only read p-codes..but i know u- codes and different codes like that will not come up...if you have the dealer scan it with the tech2 they can pull the codes
With no codes, I'd do exactly as you suggested. Unplug each wheel speed sensor and clean the contacts. Fill with dielectric grease and reconnect.
If that doesn't do it, you'll need someone that has a scantool that can watch each wheel in real time.
Thanks for the quick response guys. SloBalt 06 Did not realize that about the OBD2 reader, learn something every day. 06G5GT thanks for the confirmation, that's my next move. Will keep you posted. Thanks again.
Well, checked all sensors for damage, corrosion etc. and cleaned, lubricated with di-electric grease. Still no luck. warning lights still on. Also disconnected battery for 30 mins, but it did not reset.
So I guess I'll bit the bullet and have it scanned. Thanx for the ideas.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
